Hi Guys,
I am hoping one of you can point me in the direction of what I need or suggest the best way for me to go about this.
I am building a 35" mono for use in surf. I am trying to work out the safest, simplest and most secure way to secure my top hatch (11"x4") to my hull.
I need it to be locked down in some way, it cannot just be held there by using hatch tape.
I was thinking I would epoxy in 6-8 threaded stainless bolt threads around the circumference of the hull opening that would protrude through holes drilled in the hatch cover. These would then be used with wing nuts (or similar) to screw down the cover and hold it tightly in place against the rubber hatch seal. It would be strong but time consuming to change out batteries etc.....
Is there a better option???
Thanks, Salty.
Thanks, Salty.
