Genesis catamaran ???
Scott that is exactly in between the 3rd & 4th hole out on the arm. That is measuring for the center of the screw hole on the center postComment
4 will give you a little more throw than 3.. but 3 would be more than enough. Ive got mine where they are and have my steering rate at about 60% I think. And even at that, unles Im kickin the boat around from almost a dead stop in a slow motion, I never turn the wheel more than a degree or 2 anyway. Id put it on 3.
Thats the hole i planed on try first . If i get a CF prop, this is the one you recomended correct ?. http://www.offshoreelectrics.com/pro...od=grp-2317.40
And check the stock size.. I think its close to 40ish???? I cant find mine.. its temporarily MIA.Comment
Yeah, Id get the 42 as well. Just so you have a couple options and see how it does temp wise. Like I said, I ran pretty warn on a X440, but it also didnt really sound like the prop was winding as it shoudl have been. Like it was too deep...
________
Maine dispensaryLast edited by FighterCat57; 02-15-2011, 12:04 AM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Mudl uses those german Raceboats powertrims on is twin BJ. He told me they are very good quality
the pb fasttech prop is good and readily available at your lhs 1.6" x 2.5" Composite Propeller
link
3/16 with a 3mm adapter sleeve i drill them out for 1/8"Comment
This hull looks very strong, do you think it' s necessary to reinforce the GENESIS hull. If yes, where? Hull joint or more, ThanksComment
The cheaply made (but pretty!) Chinese boats always need reinforcing. If you want a strong strong hull without extra work, you'll pay more money for it.
No matter what, you're gonna end up paying for it! ;-)Mini Cat Racing USA
This Genesis cat is very well made, more stronger than the HOTR hull, reallyThis cat can be compared with HM hull
G3 Racing stickers are great, I' ll put a big G3 Racing on the front under the numberAttached FilesLast edited by Alfa Spirit; 06-30-2010, 08:59 PM.Comment
I agree... built waaaaay better than the HOTR 32.Comment
I' m waiting for Raceboats powertrims and a 120mm Hopf rudderLast edited by Alfa Spirit; 06-05-2010, 01:25 PM.Comment
