i buy 25% of my stuff from china but most local to support bussiness plus i hate waiting ,quick service trumps price for me anyday
Genesis catamaran ???
FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Here's a Genesis with a Neu 1521 1Y on 6s, X640, Turnigy 180a esc, and 2 x 5000 mah 3s.
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I have a set of 3 x G3 RACING stickers for Genesis hull, this cat is an anamazing offshoreLast edited by Alfa Spirit; 06-30-2010, 08:54 PM.Comment
I run my gesisis with the stock motor and a 40mm prop, on 4s & a HW 180 esc. The motor is getting to 170 after a run. I have plenty of water flow. The strut is level with the bottom of the hull. I set it by putting the boat on a table & lowering the strut untill it was flat on the counter. This is how (Tiqueman or Scott ) told me to set the strut as a starting point. Is anyone else getting motor temps that high ?.Comment
Also does anyone know if a neu smooth can 1515 1y or a castle finned can 1515 1y will fit in the stock motor mount ?.Last edited by rchippie; 06-12-2010, 08:54 PM.Comment
The Neu or castle will fit the stock mounting holes... you may have to do someting about the forward support though?Comment
Did you try raising the strut? Did it look to be running wet? Maybe a smaller prop? Id look at all those options first. Sounds like it was just loading up too much. What was the esc and batt temps?
I could'nt remember if you said to raise or lower the strut, so i did'nt do either. How much should i raise it for my next run ?. The lipos were around 120 & i would say the esc was a little hotter than that. It looks like the smooth can neu might fit into the RR brace. If not i can make up something, the smaller stock prop broke on the First outing.
Hi Scott
Not sure if this has been mentioned, but this hull and paint scheme is a closely resembles a Mystic C5000R Pretty cool. Just thought I would mention sense I'm bored lol. http://www.mysticpowerboats.com/Attached FilesComment
Hi Scott
Id go up first and see what happens. May bring your temps down, but could affect hanlding... Like I said via our phone conversation, my best run yet was about 3mm higher than stock adjustments will allow you to go ( I filed the strut slot up some) and I think I was on a 440? My batts were the only thing that got hot, ut they were crappy Reedy 20C batts. Havent tried it yet on 40Cs. I still havent even got mine back together. Too much going on lately.Comment
