China best rc toys suppliers,China best rc models wholesales,Rc quadcopter made in china,Global supplier of rc helicopter,The best Rc electric cars wholesales,Nitro gas powered rc car factory,CHINA TOPWIN INDUSTRY CO.,LTD
Pictures from this site show it with decals that say "HOR racing"
Does it come like that?
The HobbyCity boat does not come w/ TFL or HOR on the side.
Originally posted by Alfa Spirit
What do you think about 2 x cheap FSD motors 540XL 1845kV with a pair of Turnigy 120A?
6S for each combo
That should work fine. Theres info on a HPR06, little longer and wider than the Genesis, w/ twin Feigao XL motors on 5S I think it is.. 8Xls? and its around 60mph.
And you can do it as you have shown, BUT.. your run times will be very short. Im running my twin HOTR on10XLs with 2 - 3S 5800mah in Series, then parallaled to each ESC, as you have shown, and if you stay on it hard, its less than 2 minutes. You have the room in the Genesis, Id give it 5 or 6S each. And I would still parallel it to both ESCs so they always see the same voltage.
Id still recommend 6S each, if thats the cell count your looking to run. Its a lot less stress on your batteries. Ive heard of some guys puffing cells and they arent even getting hot. Just from the demand and rapid discharge I guess. If I could put 2 6S batts in my HOTR, I would have done it. Im actually thinking of dropping to 8 or 9XLs in it so I can run 4S2P
The plan for now, because I have it all, is to run 10XLs on 6S2P in the HPR06. Eventually it will get Neus, or now Im looking at the Tenshock as well....
Today I decided Id try and get it a little closer to seeing the water. As w/ all new RTR boats, I pulled the shaft to grease it. Upon finding no grease at all on the flex and a small amount inside the sqare housing of the stub shaft, I also discovered that the stuffing tube had broke loose. Something all of you getting the RTR need to check. I had been over it w/ a fine tooth comb and had no idea it was loose. What Im getting used to doing now w/ RTRs is gutting the entire boat upon purchase and rebuilding it so that you know for certain everything is right.
