Carbon fiber motor cooler
  • Gary
    • Jan 2009
    • 1105
    I found some carbon fiber motor coolers from Fast Electrics and looking at the pictures of them i cant figure out how they work. It looks like a round sleeve that slides over the motor but its tight to the motor and there is no in/out tubes. What missing here? Thanks
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
  • tth
    • Apr 2008
    • 1510
    He supplies the fittings that go on the sleeve. You have to drill the holes and glue in the fittings.
    • Gary
      • Jan 2009
      • 1105
      And as far as it sealing to the motor? I see no o-rings like the aluminum units Off Shore sells.
      Chris Craft 16 mph
      • Boatman
        • Jan 2008
        • 796
        -O- rings come with them and must also be glued in place. they are light but are kinda one time use only
        • focused
          Dutch Electric Powerboats
          • Jul 2008
          • 237
          I make them myself http://forums.offshoreelectrics.com/...ead.php?t=6697 .
          Michiel.
          • andym
            More Go Than Show Prop Co
            • 2406
            Good job but a little tip you should fill from the closest point to the bottom and out at the highest point possible, at opposite ends. This makes for complete flow and better cooling
            • Simon.O.
              • Oct 2007
              • 1521
              Andy is right here, A jacket cooler should be fed from the bottom and exit at the top, good flow of coolant and prevents air locks too.
              • andym
                • 2406
                Thanks Simon, at last we agree on some thing!! I must mention that if you use epoxy these are not one use only coolers. If you heat up the ends gently with a hair drier or hot air gun you can peel the epoxy away and reuse the cooler
