how to modify a KB45 motor
  • focused
    Dutch Electric Powerboats
    • Jul 2008
    • 237
    I modified a KB45L10 motor so it runs cooler and lives longer .
    If there are question , just ask .
    Michiel.
  • focused
    • Jul 2008
    • 237
    and another 6 pics . ...
    Michiel.
    • focused
      • Jul 2008
      • 237
      and the last one.
      Motor is ready to use.
      Michiel.
      • Gerwin Brommer
        • Dec 2008
        • 918
        In short :
        - 1 shim removed
        - 7 holes drilled in back bearingshield
        - diy watercoolingjacket, made from CF
        • ghostofpf1
          • Jun 2008
          • 392
          Good Job...
          How did you get the can apart ?? I ask because I purchased better bearings for mine and want to install them the next time I pull the motor out.
          Also what benefit was gained by removing the shim ??
          thanks in advance
          Steve
          • Flying Scotsman
            Fast Electric Adict!
            • Jun 2007
            • 5190
            Well done Michiel. Every time I see the windings on a KB45..
            Douggie
            • focused
              • Jul 2008
              • 237
              I used a hammer on the shaft holding the motor in my hand , and the rear shield will come off .
              Michiel.
              • Gerwin Brommer
                • Dec 2008
                • 918
                Doug.
                Windings or spaghetti ??
                • Flying Scotsman
                  • Jun 2007
                  • 5190
                  Gerwin, more like in Scots vernacular you take the high road and I take the low road and I will will meet in the KB45 case God knows where
                  Douggie
                  • focused
                    • Jul 2008
                    • 237
                    Douggie
                    True , but if it works i dont care how it looks from the inside .
                    Michiel.
                    • Punisher 67
                      Ignore list member #67
                      • May 2008
                      • 1480
                      Wow very well done.....................
                      • Gerwin Brommer
                        • Dec 2008
                        • 918
                        @ Steve :
                        1 shim is removed because the 2 shims is too much.
                        Both bearings are pushed to the outside too much ( = friction = heat, etc etc etc) with the 2 shims.
                        • DISAR
                          • Aug 2007
                          • 1072
                          Gerwin & Michiel,
                          The 2 shims issue applies also for the XL? What did you put first on the silicon tube and on top of it the CF?
                          Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
                          http://www.rcfastboats.com/
                          • Gerwin Brommer
                            • Dec 2008
                            • 918
                            Yep, same thing for the XL's.
                            What you see in the pics is plastic.
                            Small plastic bag, the kind we put our bread in when going to work/school
                            refridgeratorbags are similar ?
                            The plastic foil you use to keep your food in the kitchen will work to.
                            Or baking/stofe-paper.
                            • egneg
                              • Feb 2008
                              • 4670
                              How thick were the shims? I had to take mine apart when I saw this and found that there weren't any. I have to add that this motor (a standard KB45) was given to me and apparently they had been removed. I checked the end play and it was 0.003" is this too much?
                              IMPBA 20481S D-12
