I found some carbon fiber motor coolers from Fast Electrics and looking at the pictures of them i cant figure out how they work. It looks like a round sleeve that slides over the motor but its tight to the motor and there is no in/out tubes. What missing here? Thanks
Carbon fiber motor cooler
He supplies the fittings that go on the sleeve. You have to drill the holes and glue in the fittings.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio * -
----------------------Comment
Andy is right here, A jacket cooler should be fed from the bottom and exit at the top, good flow of coolant and prevents air locks too.See it....find the photos.....sketch it it....build it........with woodComment
Thanks Simon, at last we agree on some thing!! I must mention that if you use epoxy these are not one use only coolers. If you heat up the ends gently with a hair drier or hot air gun you can peel the epoxy away and reuse the coolerComment
