Need Info in a KB45 vs. Neu
  • 4Speed
    • 30
    Are these motors any good? If I wanted to upgrade to a Neu motor would I be looking at the 1521 series?
  • sailr
    • Nov 2007
    • 6927
    OSE dropped them if that tells you anything. It is nowhere near the quality and power of the NEU in my opinion.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Jeepers
      • May 2007
      • 1973
      The Neu is the much better motor, however you may not need a 1521. what hull and set up are you planning on using???
      • 4Speed
        • 30
        Scale boat 33" with submerged prop. Have a Fine Design transmission so I dont want to be motor limited.
        • forescott
          Hopelessly Addicted to RC
          • 2686
          Consider a Castle creations motor. OSE sells them, a bit cheaper than neu.
          • Jeepers
            • May 2007
            • 1973
            sounds like a scale runabout. why don't you post a pic or 2.
            a 1521 would probably shred those plastic gears on the FDM transmision you wont be limited with a Neu.
            again more info needed
            • 4Speed
              • 30
              Photos (if the upload works)
              • 4Speed
                • 30
                More
                Photos
                • Steven Vaccaro
                  • 8723
                  From the looks of it, you dont need that much of a motor.
                  How fast do you want to go? 15-20MPH?
                  • RCprince
                    • Jul 2007
                    • 1637
                    How about a BJ Motor.
                    • Steven Vaccaro
                      • 8723
                      Good idea. But make sure to use a Castle Hydra 120 or something else with reverse. It would be a shame to have a scale both without reverse.
                      • Jeepers
                        • May 2007
                        • 1973
                        on 2s with lots mah, run forever!
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          That boat screams Graupner 700 8.4bb to me......................10-14 cells. Big workhorse motor with internal cooling fan and you can add brush cooling very easily.
                          • RCprince
                            • Jul 2007
                            • 1637
                            I doubt that 700 has more power than the BJ motor, plus being brushless it's more efficient...The BJ motor is 6 poles and well built.
                            • 4Speed
                              • 30
                              We race the scale lobster boats in Maine. My current boat (not the one pictured) is the mid west 30" balsa lobster boat kit that will run 22.6 MPH on GPS with a Hacker 11XL B50 with (2) 9.6 volt sub C pattery packs in series. I have set these boats up in some cases with trim tabs, water cooling & flex shafts with the teflon lined tube, T bars you name it (been in RC for 20+ years). The races start from a dead stop & run about 75 yars around a bouy & back. The hull pictured is a new Bluejacket and its fiberglass so I am thinking 25+ MPH for this one. The most difficult issue with the build is setting the height & length of the spray rails as with this type if semi round bottom hull, the rails are extreamly critical as they control the attitude of the boat.
