Name this hull
  • rchippie
    • Jan 2010
    • 567
    Name this hull
    I just acquired this hull today from my boss at the hobby shop for FREE. What brand of hull is this & is it worth converting to electric ?. It's 36 inches long.
  • Eodman
    • Sep 2007
    • 1253
    My first answer is YES. But I have never converted a gas hull before ... so don't listen to me!
    We did it with a Bang!
    Cats Are Where It's At!
    • m4a1usr
      Fast Electric Addict
      • 2038
      looks like a Dumas to me.
      John
      Change is the one Constant
      • RandyatBBY
        • Sep 2007
        • 3915
        It is a Prather Lap Cat a old one, I think never know My memory sucks some times. It could be a fun boat they all take work. I would run cheap 8XL on 4S2P and a 440 prop possably a 442 prop.
        Randy
        BBY Racing
        • RandyatBBY
          • Sep 2007
          • 3915
          It is a Prather Lap Cat a old one, I think never know My memory sucks some times. It could be a fun boat they all take work. I would run cheap 8XL on 4S2P and a 440 prop possably a 442 prop. How big is it?
          Randy
          BBY Racing
          • rchippie
            • Jan 2010
            • 567
            Randy it's 36 iches long . Can i convert the lower k/b unit or does it need to be replaced ?.If i cant convert the lower unit is it worth anything ?.
            • crabstick
              • Jul 2008
              • 954
              yeah im pretty sure thats a prather lapcat, the K&b lower unit can be converted to FE
              Matt.
              FE, Nitro and Gas racing in Auckland
              www.rcboats.co.nz
              • rchippie
                • Jan 2010
                • 567
                Do you know about what it cost to convert it ?. It would make things eaiser. Because it's all ready mounted to the hull. No need for new holes .
                • crabstick
                  • Jul 2008
                  • 954
                  unsure of cost, I have seen a converted one and the 4 bolts used to secure the power head were used to make a mounting plate, it had machined spacers about 30mm long then a flat motor mount plate bolted on top.
                  as much as i dislike RC universe for all the mis-information on there here is a link to a converted one
                  Speed - Electric - K&B electric outboard conversion? - Hi I'm planning to build an F1 tunnel hull with a K&B electric outboard conversion and need some expert help please..... I checked a few website and it seems that they sell only complete nitro engines. If you've done it can you please help me in terms: 1. What
                  Matt.
                  www.rcboats.co.nz
                  • rchippie
                    • Jan 2010
                    • 567
                    After looking at pics online . My lower unit is missing the fin at the bottom . So i assume it is no good. Is there a affordable lower unit that can handle a 580xl motor ?. Or am i SOL ?.
                    • crabstick
                      • Jul 2008
                      • 954
                      might still be ok as you are using angled prop wash to turn.
                      Matt.
                      www.rcboats.co.nz
                      • rchippie
                        • Jan 2010
                        • 567
                        O'really how can i find out if it's still good ?.
                        • crabstick
                          • Jul 2008
                          • 954
                          Theres some Ausi's who are running o/b's maybe they have tried without the skeg, have a search around on here personally id try it and then keep a look out for another lower unit with skeg, least then you can use it to mock up the engine mount etc.
                          Matt.
                          www.rcboats.co.nz
                          • rchippie
                            • Jan 2010
                            • 567
                            I wonder if i have any other options ?.
                            • crabstick
                              • Jul 2008
                              • 954
                              could always out a strut and rudder on it.
                              think this one has a surface drive strut setup.
                              Matt.
                              www.rcboats.co.nz
