TC 31 Brushless Conversion
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    #106
    I would run 5S ...1 3S and 1 2S in series and after viewing data on an Eagle Tree for different props etc. I may purchase 1 3S and run 6S. Unfortunately this may not be the fastest setup with the items you have purchased but it will still be FUN and a great learning curve.
    Douggie
    • dddmx3
      • Mar 2010
      • 233
      #107
      Really? Mann. Ok so I'll try to order two 3s lipos and a 2s.. About 25c's, and 5000mah right
      After all is said and done, more is said than done.
      • Flying Scotsman
        • Jun 2007
        • 5190
        #108
        I would start with 5S and buy the other 3S later. The batteries must be identical...same manufacturer, same series, same C and Mah. This is just my suggestion for what you have already purchased.
        Douggie
        • dddmx3
          • Mar 2010
          • 233
          #109
          Hey Douggie i found this lipo but its 4000mah.....
          thank you so much for helping me so far!
          p.s. there is a 5000mah but idk do i need it?
          • Flying Scotsman
            • Jun 2007
            • 5190
            #110
            Do not get me wrong. The limiting factor in your setup is the motor and the size/weight of the hull it really needs a 580 series or a Neu, but will be fine with your 12XL and 5S or 6S and a conservative prop to begin with and starting with your COG at about 30%. Also I strongly suggest you buy the extra cap bank for your ESC. Enjoy your build and use a thrust bearing on the motor http://www.offshoreelectrics.com/pro...hrust+Bearings
            Douggie
            • dddmx3
              • Mar 2010
              • 233
              #111
              Im going to order this LiPo.. 4000Mah, 20c... Douggie is this ok??
                • 9479
                #112
                Looks like a decent price for 5s ?
                • ozzie-crawl
                  • Sep 2008
                  • 2865
                  #113
                  12 xl on 6s with somthing like a y537/3 shouldnt pull anymore than around 55-60 amps
                  the hull rtr run shouldnt be anymore than 2.5 kg (5.5lbs) if done rite
                  • brad65ford
                    • 17
                    #114
                    Great broke the crank on the first run of the season this year. Humm maybe brushless, it's 120 shipped for the nitro.
                    • dddmx3
                      • Mar 2010
                      • 233
                      #115
                      Finally boat got back from painting.
                      A friend painted it for me, its black with Monster Stickers and of coarse the trailer I welded.
                      Pictures should be up today...
                      Im going to put it together, take a dry run,
                      and get it in the water, Hopefully soon!
                      Hull is 1.5lbs (pounds)
                      with nothing in it.
                      • dddmx3
                        • Mar 2010
                        • 233
                        #116
                        Finished!
                        I have to get my boat in the water and test it out.
                        Here are some pictures, tell me what you think!
                        • Flying Scotsman
                          • Jun 2007
                          • 5190
                          #117
                          nice paint job, though it may be hard to see on the water. I might suggest you shorten up the electrical leads and replace the Deans with bullet connectors.
                          Douggie
                          • dddmx3
                            • Mar 2010
                            • 233
                            #118
                            Alright I'll switch the connecters. You mean by leads, the wire length right?
                            • m4a1usr
                              Fast Electric Addict
                              • 2032
                              #119
                              The battery wires off the speedo are pretty long. Can you route things closer? Ditch the deans. Go bullets.
                              John
                              Change is the one Constant
                              • dddmx3
                                • Mar 2010
                                • 233
                                #120
                                That's the thing idk where to put the speedo!
                                How much shorter should I cut the wires?
                                Would if I cut off about 5in like whats circled
                                green in the picture....
