Shockwave 36 Electric conversion
  • Team A-Hull
    • Aug 2007
    • 69
    Steve, do you have any pics of this build? Wouldn't mind seeing the setup inside.
    Thanks
    Jason
    Where just a bunch A-hulls with boats...
    • Steven Vaccaro
      • 8721
      I will dig it out and post some tonight.
      • Team A-Hull
        • Aug 2007
        • 69
        Cool!!! It would help out alot!
        Thanks Steve
        • Steven Vaccaro
          • 8721
          There's not too much to it. I need some stainless screws for the motor mount. As you can see, what I have is rusting.
          • Team A-Hull
            • Aug 2007
            • 69
            Sorry one more question...
            Can't seem to find the motor mount... Where did you find yours?
            Thanks Jason
            • Steven Vaccaro
              • 8721
              Jason thats the only slightly difficult part. I made it.
              I used a very heavy gauge aluminum because it was all I had.
              I first unscrewed the front motor plate from the kb45. I than made a photo copy of it to use as a template. Than glued down the template to the aluminum and drilled the holes. And than just made the bends with a metal brake. There are some cheap metal brakes on the market. It took about a nights work, but came out good.
              • FE_Chris
                • Jun 2007
                • 764
                Nice Steven I dig the conversion! Very Cool! I always wanted to do one of these or a TC31 myself...glad to see it works well.
                • SJFE
                  • 4735
                  #23
                  I made a template out of thin birch. I marked the ouput shaft and used an exato knife to round out a tight fitting hole. Then slid the birch down the shaft to the can and traced it. Cut that out. Last i marked the bolt holes on the edge of the can and probed inward with the tip of the exacto blad until I found & marked them all. Then just rounded them out with the blade. I got a perfect template out of that. I will be sending it off with the motor as a matter of fact. If anyone wants a copy let me know before friday and ill make it.
                  • Team A-Hull
                    • Aug 2007
                    • 69
                    #24
                    Steve and SJFE thanks for the input!
                    I wasn't sure Steve if you made that or not but that is a nice way to approach it.
                    SJFE
                    What hull was that again you posted in this thread. First off, NICE setup! That is a work of art and should be framed on a wall after it's been driven hard. Thats the final result I aiming for. The motor mount; are you talking about a motor mount similar to the picture posted earlier that would work in my shockwave 36?
                    Thanks for the help!
                    • robby76
                      • 190
                      #25
                      is this SW36 project worth venturing into? am looking to build a mono hull. usually windy at lake so a good wave cutting, performing hull will be my direction.
                      • SJFE
                        • 4735
                        #26
                        Iwould say yes. Look @ the results Steven got from a quicky setup. Stripped of its weight on s6 with that big KB this baby will be a FUN quick boat.
                        • Steven Vaccaro
                          • 8721
                          #27
                          It runs good. But its no wave crusher. I'm sure I can put the tabs down a bit more but the speed will be sacrificed.
                          • SJFE
                            • 4735
                            #28
                            Well I got one. T- One week for delivery. Going with the 11XL as advised HM200 amp esc. Batteries TBA....
                            • Magnus
                              • Apr 2008
                              • 2
                              #29
                              How are you going to mount the motor?
                              I'm looking to convert my SW36 to elec asap.. Its nice outside and I want to run it!! :)
                              • SJFE
                                • 4735
                                #30
                                I am using a custom made rail mount.
