is there a spray foam that i can use for rc boats ?
This topic is closed.
  • westbeach
    OSE Rocks!
    • 951
    Guys, this expanding foam stuff, is it guaranteed not to expand further after the initial application?? Say you apply the stuff in wintertime, when summer comes and the season starts again. With the summer heat and and enclosed hull, will it expand further?
    Just curious
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • hydromaddicted
      • 83
      Go to your local kayak shop and get a block of minicell foam and cut shape and glue some in the empty spaces of your boat.http://www.nrsweb.com/shop/product.a...76&deptid=1764
      • sailr
        • Nov 2007
        • 6927
        Holy crap! That stuff's way too expensive when you consider a pool noodle will do multiple boats and they're only about $2!
        Mini Cat Racing USA
        www.minicatracingusa.com
          • 9488
          Originally posted by Doby
          Use "Great Suff", low expansion foam.......only do a small section at a time,,,let cure 24 hours and repeat over several days until the cavity is full...
          Do not try and do the whole cavity at once!!!!!!!!!!!!!!!!!
          This will add all the flotation you will need, at the same weight of pool noodles AND will add strength to the hull,,which pool noodles DO NOT.
          Doby, I took your advice months ago about how to use the great stuff and this is how I do all my boats including my gas KOS..
          I like how it makes the hull more ridged, especially for my big KOS
          • Steven Vaccaro
            • 8718
            Do you guys notice if the Great Stuff absorbs water at all?
            • Gary
              • Jan 2009
              • 1105
              I use it all the time and never had that issue at all.
              H&M 1/8 Miss Bud 73 mph
              Chris Craft 16 mph
              • Doby
                KANADA RULES!
                • 7280
                Using it for years now and NEVER any issues.
                Grand River Marine Modellers
                • LiPo Power
                  DJI Drone Advanced Pilot
                  • May 2009
                  • 3186
                  #23
                  Great info on expanding foam. Can someone answer post #3 quastion please????
                  Thanks
                  Canada
                  • sundog
                    Platinum Card Member
                    • Feb 2009
                    • 878
                    #24
                    Thanks
                    What question? That looks like a statement, and I don't agree with it. Once it is cured, it is closed cell and water shouldn't be getting behind it or absorbed by it. I've been using spray foam. Follow Doby's suggestion and no worries. It stiffens and quiets lightweight hulls and the pieces of your smashed boat will float back to you (Ha!). I've used both noodles and foam for different applications.
                    The low expanding stuff wasn't available ten years ago. I have also had an ABS plastic hull almost bust apart from applying too much foam at one setting. But I learned from the experience.
                    Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
                      • 9488
                      #25
                      No, not at all..
                      as long as you do not cut the foam it will keep water tight
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1679
                        #26
                        I know pool noodles soaks up water over time.
                        • daveives
                          • Jun 2009
                          • 109
                          #27
                          Why not glue in the pool noodles with low expanding foam?
                          • sundog
                            • Feb 2009
                            • 878
                            #28
                            Sweet! I'm sure there's an application where that would be best. That stuff is crazy sticky and tenatious once cured. I like that thinking!
                            • CornelP
                              • May 2009
                              • 745
                              #29
                              It is excellent as glue. I attached some foam panels to steel cabinet doors, like a charm. What you need to do to stop expanding is what they call killing the foam... apply on one surface, make contact with the second, hold a couple of seconds, remove, wait 5 min and put parts together again... it will hold forever and will not expand.
                              • damfurst
                                • 261
                                #30
                                I found this at Home Depot next to the Great Stuff foam and decided to give it a try. It is a little more expensive but I was able to fill in the bow of my Mhz Gecko in one shot. Let it set for a day or 2 close to the heater to cure. It doen't ever hardened and is easily removed if you need to. I had to cut part of out so my motor would fit very easy to do and trim just how you want it.
