MHZ Lizard motor, esc and battery combo
  • lizardfan
    • Dec 2009
    • 21
    Wow, those ESC really are expensive!
    Isn't there maybe a cheaper alternative, you know to just get started?
    • Gerwin Brommer
      • Dec 2008
      • 918
      • Flying Scotsman
        Fast Electric Adict!
        • Jun 2007
        • 5190
        Gerwin, I was not aware of that product. I have Turnigy ESC's and they are real bang for the buck.
        Thanks for the heads up as I am going to order one right now.
        Lizardfan, please note their is no water cooling. I will build my own.
        Douggie
        • Gerwin Brommer
          • Dec 2008
          • 918
          I'm wondering if you could watercool this esc. like an Schulze 40.160 !
          The first thing that went through my mind when I saw a photo of the Turnigy was :
          same "base"? ( as the Suppo esc in photo: )
          • lizardfan
            • Dec 2009
            • 21
            Originally posted by Gerwin Brommer
            Ok, 200A esc. How about watercooling? Is it possible to make something out of say brass tubing? Or maybe alloy.
            180$ seems affordable. What sort of battery would you then run on this? Still 5-6s?
            • Flying Scotsman
              • Jun 2007
              • 5190
              Yes, brass as shown by Gerwin that ESC is rated up to 12S. It is up to you as far as batteries are concerned.
              The gentle Douggie but he may lose his cool
              • lizardfan
                • Dec 2009
                • 21
                Ok, I will order the esc Gerwin linked and run 3s2p 5000mAh 30c (in parallel or series??) How'd you recon that would peform??
                I'd have to create some sort of watercooling for the esc, but I have some ideas in mind.
                Thanks so much for the help so far! Now I actually have an idea on how to set these boats up. cheers
                Sebastian
                • Gerwin Brommer
                  • Dec 2008
                  • 918
                  You already have cells or do you have to order them ?
                  • lizardfan
                    • Dec 2009
                    • 21
                    Unfortunately I'd have to order them. Why are you asking? As said before, please correct me if I'm doing anything wrong - amperage, cellcount etc - as I'm still quite lost.
                    Sebastian
                    • Gerwin Brommer
                      • Dec 2008
                      • 918
                      buy 2x 5S 5000 30C , that's what I would do
                      The Turnigy's or Zippy flightmax
                      • lizardfan
                        • Dec 2009
                        • 21
                        In series or parallel?
                        • Gerwin Brommer
                          • Dec 2008
                          • 918
                          #27
                          parallel, otherwise you havea 10S pack !
                          • Jeepers
                            • May 2007
                            • 1973
                            #28
                            we have a guy in the club that runs one in LSO, he runs a BJ 26 on 4s and has no problem running 4 minutes with a 45 mm prop it ran pretty much all season on this set up reliable as well!
                            For more speed this hull can be powered on 4s and run a 1521 1.5d and run in the 50s range. and you dont need an HV speed control!
                            I have ran a a 1521.1.5d on 4s1p 4350mah with a m545 in a 31"mono (non lizard) hull and had more power than the hull could handle!
                            Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                            • Gerwin Brommer
                              • Dec 2008
                              • 918
                              #29
                              that's an option to !
                              I think I´m not racing orientated enough.
                              But i would not compare the boat in your video with a Lizard.
                              Yours is not that bulky, has less V and doesn't weight as much as a lizard.
                              Over here in Europe I've never seen a Lizard on 4S.
                              • lizardfan
                                • Dec 2009
                                • 21
                                #30
                                Ok, going to see if I have the time to place the order tomorrow.
                                By the way, I just took a look on the measurements on that ESC, and it's absolutely huge!
                                125mm long
                                60mm wide
                                38mm high
                                - that's insane! I just hope that it will fit in the boat.
                                Anyways, happy newyears eve from Denmark
                                regards
                                Sebastian
