Whipash props
  • Raydee
    • May 2007
    • 1603
    Whipash props
    I am just curious what props you guys are running on your Sport 21 Whiplash hulls. I normally run X series 445 and 645 props with great speed but lower run times. My bud recently gave me a 14 series 1445 to try and this prop really seemed to be the ticket. THe boat is fast and will run about a minute longer with lower temps on the ESC and motor. The cells come out of the water between 120*- 130* but that isn't bad considering I am running 1p in my hull. I am def going to try the ABC H series props next season. The only thing about the prop is I am getting a little hop in the turns but I am going to try to tweak the prop and see if that goes away.
    Team Liquid Dash
  • detox
    • Jun 2008
    • 2318
    Move the COG back toward stearn a little bit more.
    • tth
      • Apr 2008
      • 1510
      I like the M545 and M645.
      • Jeepers
        • May 2007
        • 1973
        I like the m646,m447 and m648.
        I run 4s1p 6500 35c hyperion packs, 1521 1.5d, hydra 240. Yesterday I ran a m447 full mill lap, plus 6laps on a 1/6 mile, plus an impromptu race against Disrtrict 20 director Robert Holland's UL1. I pulled 3463mah out of the packs according to my charger, temps were 93 packs 87 esc 104 motor no water cooling on motor.
        I also ran this set up at the MCX 10 Nats.
        • ray schrauwen
          • 9472
          Nice setup Jeepers.
          I have both the 1515 1Y and a 1521 1.5D. I wasn't sure about the 1.5d but, with your numbers, I like it. I will setup hull so I can hopefully switch the 2 motors out with proper cg still.
          Where is your CG and how is that turn fin?
          Nortavlag Bulc
          • Jeepers
            • May 2007
            • 1973
            Nice setup Jeepers.
            Thank you Ray
            My CG is all over the place! Its about 1 3/4 from the back of the sponson right now... Sunday I ran it in massive chop (right after gas mono and cats ran) plus high wind, every time it left the water it flew perfectly level, I wasnt afraid to run her wide open. the turn fin is one of Fullers stainless fins(the $49 one) that I cut down, this boat corners flat and on rails. I love this Whiplash!
            I wish I had built mine to swap to different size motors but the motor mounts are screwed and glued to G10 fiber glass and then fiberglassed and epoxyed to the bottom of the hull. 1521 is the only thing that fits in the mounts.
            • ray schrauwen
              • 9472
              Thats not true. You can figure it out... or do I need to explain how to do it?
              Nortavlag Bulc
              • Jeepers
                • May 2007
                • 1973
                LOL! HEY your right a 1527 would fit LOL!
                • Scott T
                  • Oct 2007
                  • 590
                  I am having a lot of success with an ABC 1614/3 Chopper on mine. 1515/1Y for power.
                  Scott Tapsall
                  Pine Rivers Model Powerboat Club - Facebook Page
                  My Gallery
                  • sailr
                    • Nov 2007
                    • 6927
                    anyone running the whip with LSH spec setup...UL-1 motor? I'd be interested in your prop choices.
                    Mini Cat Racing USA
                    www.minicatracingusa.com
                    • Raydee
                      • May 2007
                      • 1603
                      Scott, I have one of those 1614/3 bladers on the way from CDMI to try out. I always said a 3 blade 42mm would be the ticket in this hull. The 440/3 works pretty well but just a tad slow on the back straights.
                      Team Liquid Dash
                      • Scott T
                        • Oct 2007
                        • 590
                        Good one! You won't be disappointed
                        Scott Tapsall
                        My Gallery
                        • Raydee
                          • May 2007
                          • 1603
                          I received my 1614/3 today from CDMI. They did a real nice job on the prop and I can't wait to try it out tomorrow.
                          Check out some vid of out Whips running last weekend, I am hoping the 3 blade ABC prop smooths out my hull but keeps the speed.
                          Team Liquid Dash
                          • tth
                            • Apr 2008
                            • 1510
                            Lookin' good Ray......she has come a long way from the beginning.
                            • detox
                              • Jun 2008
                              • 2318
                              The White hull appeared a little more stable, but slightly slower. The Yellow hull is slightly faster, but less smooth. Are both hulls setup the same (COG, motor/esc, motor/battery placement)?
