Need help with stinger strut
  • BILL OXIDEAN
    Banned
    • Sep 2008
    • 1494
    Hey Gents,
    I've got an ETTI stinger strut for one of my sport monos (ETTI oriental Dragon) and it has an enormous hole in the backplate where the stuffing tube goes, but its way too big to support a 130 cable..
    Anyone got pics?
  • longballlumber
    • 3119
    Bill,
    Does your strut have lead bushings or is it the style that extends the stuffing tube thru the strut and then install a brass bushing?
    • properchopper
      rcgoatbuild@snotmail.com
      • 6953
      Post some pictures; the term " enormous hole " is, er, rather ambiguous !
      • BILL OXIDEAN
        Banned
        • Sep 2008
        • 1494
        Here are some pics..
        • domwilson
          Moderator
          • 4405
          On my speedmaster stinger, I extended the stuffing tube about 3/16" from the hull and let the teflon liner extend another 1/2". Works for me.
          Government Moto:
          • BILL OXIDEAN
            Banned
            • Sep 2008
            • 1494
            Any pics?
            • domwilson
              Moderator
              • 4405
              Sorry. The boat is already assembled. But I just scanned the instructions for you.
              Government Moto:
              • BILL OXIDEAN
                Banned
                • Sep 2008
                • 1494
                thanx man! but I'm still confused..
                • domwilson
                  Moderator
                  • 4405
                  So was I. But I did notice the
                  "[note]
                  Brass tube should protrude 1/8 in. out of transom to fit in bracket."
                  Bracket being the mount to the transom. Yeah...Didn't really see a "B" in those instructions to reference against the diagram. Yeah, no "b"
                  Government Moto:
                  • properchopper
                    • 6953
                    I'm guessin' here, but it looks like, since the mounting holes allow for up & down vertical adjustment, the "enormous hole" can allow a normal sized stuffing tube some clearance when this adjustment is made. Pix of Speedmaster 21/40 stinger.
                    • BILL OXIDEAN
                      Banned
                      • Sep 2008
                      • 1494
                      I'm starting to figure it out, I'm just used to the strut itself supporting the tube, but in this case it will be mostly silicone, but more input will be appreciated
                      • properchopper
                        • 6953
                        the stuffing tube will be supported when it passes through the transom hole which should approximate an interference fit.
                        • 6S HYDRO
                          • 1320
                          Some of those stingers are designed for square drive setups that use a larger shaft at the nose end of the strut
                          • Jeff Wohlt
                            • Jan 2008
                            • 2716
                            Billy, got your pm on the shafts and couplers. I have to wait on more shafts. When do you need them?
                            www.rcraceboat.com
                            jwohlt5362@yahoo.com
                            • Ctonez
                              • Jul 2007
                              • 404
                              I have the same hardware on the back of my Mogli...came with it from Ray (via RMCK), and is the only drive that fits on the moglis.
                              It is indeed a strange diameter. I made myself a custom bushing out of some brass tubing and loctite 603. To make everything fit correctly I had to get the brass tubing size just bigger than the hole (5/32 tubing I think, but that's from memory) and sheath concentric brass tubing down to 3/16 for my shaft. Then I put the whole thing in the drill and sanded the bushing until it just fits into the RCMK strut and viola.
                              Confusing?
                              Another way to do it is to start with the 5/32 tube and thin the OD down so you can fit it into the strut...then loctite 603 that into the strut and your strut is now a standard inner diameter with a nice brass surface for the bushing/shaft.
