Dynamite 3835 1500Kv
  • TRUCKPULL
    • 2969
    Is this motor (Dynamite 3835 1500Kv) a "D" or a "Y" wind
    I know that it is a 6- pole 2 -Turn Wind??
    Larry
  • 30nitro
    • Feb 2018
    • 330
    I have the same motor...is anodized blue..?? I'd like to know what wind it is also....
    • Doug Smock
      Moderator
      • 5272
      If you can't see the Y connection inside the end bell it is a D.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • TRUCKPULL
        • 2969
        Thank you
        Doug
        I have misplaced my little black book with all my motor info in it.
        I just changed the ESC in that boat, went to set it up and I could not remember the wind, for the timing.
        I should scribe it on the motor. "Y"
        Larry
        • Doug Smock
          Moderator
          • 5272
          I find myself doing the same thing Larry. But still...Old guys rule!!
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Revolt Flash
            • Aug 2015
            • 437
            Does anybody have a cheat sheet on the Dynamite motors?
            • 30nitro
              • Feb 2018
              • 330
              Cheat sheet....That'll work...!!!!
              • donhuff
                • Dec 2014
                • 561
                Larry,
                The 1500 is a 2 Wye.
                The "Y connection" is that little piece of black heat shrink, pressed down on top of the wire, in the rear of that motor. It's small and hard to see in that motor.
                Flash,
                What do you mean by cheat sheet?
                AmpDaddy
                don huff
                • TRUCKPULL
                  • 2969
                  Rafael
                  Say's it is a "D" wind
                  Getting old sucks
                  Larry
                  • Revolt Flash
                    • Aug 2015
                    • 437
                    Originally posted by donhuff
                    Larry,
                    Flash,
                    I mean by having a list of the Dynamite motors and having them listed as either D or Y wind so you could have a good starting point for the timing.
                    • TRUCKPULL
                      • 2969
                      Dynamite -3835 - 1500kv - 6 pole - 2Y
                      Dynamite -3831 - 2000kv - 6 pole - 1.5D
                      These are the only two that I use
                      Larry
                      • ray schrauwen
                        • 9472
                        Thank you! I was assuming the 2000 was Y.
                        Nortavlag Bulc
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4286
                          Adding to Truckpull's list:
                          Dynamite -3835 - 1500kV - 6 pole - 2Y
                          Dynamite -3831 - 2000kV - 6 pole - 1.5D
                          Dynamite -3910 - 2000kV - 6 pole - D
                          Vac-U-Tug Jr (13mph)
                            This could be why some members find the 2000 Kv motors to run hot. Thinking it was a Wye motor and then running the Delta motor on 10*-15* advance could be expected to build extra heat.
                            • Revolt Flash
                              • Aug 2015
                              • 437
                              Does anyone know what the 3930 1750kv 4 pole or 3935 1650kv 6 pole are.
