Burnt out motor
  • Doug Smock
    Moderator
    • 5272
    #31
    Any chance the motor mounting screws were a bit too long?
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Speed3
      • Mar 2017
      • 371
      #32
      A 4092 have enough torque to break the solder joint which holds the flex cable to the solid metal piece which holds the prop.
      Check the shalf good and see if the solid part holding the prop is holding firmly to the flex cable.
      Because that prop you mention is enough load to cause a breakdown like this.
      • PieterSmith
        • Feb 2018
        • 10
        #33
        Hi Gents
        prop was defenetely the cause of the burn out. 69mm prop way to big.
        As for the GoolRC 160A ESC, programming is done via transmitter and counting Beeps
        No programming card required.
        https://hobbyking.com/media/file/606792873X68524X7.pdf
        After all the running around and money spend on program cards and 2 still on order, wish i had found this earlier.
        Solved the programming issue
        i hope this helps all who in future use the GoolRC 160A ESC
        • Bp9145
          • Jan 2016
          • 1466
          #34
          Glad you solved the programming issues. I sent you a pm I don't know if you got it but could you let me know either way if you received it or not. . .thanks
