New TP motor only a few runs shaft spun out?
  • robw
    • May 2014
    • 58
    #61
    had same problem with a tp motor in a mcd v4, spun its shaft in the rotar, don't know if grub screws had sheared but there wasn't much of a flat spot on either end of shaft, tp replacing foc, they told me they now use a different glue so problem shouldn't happen again, to be fair to tp they were very good with their after sales service, so good ive ordered another tp motor off them
    • tlandauer
      • 5666
      #62
      Originally posted by bayareaheli
      I will forsure, here is my motionless cheetah for now lol
      Wow, very nice looking boat, the tug is nice too.
      • bayareaheli
        • Jul 2014
        • 144
        #63
        Thanks tlandauer!
        • bayareaheli
          • Jul 2014
          • 144
          #64
          Got my TP motor back and installed.
          I have a question about my TP motor Timing
          here are the Parameters:
          T: 3Y
          KV: 1720
          Max Amps (A): 213
          Max Volt (V): 29
          Continuous Power (W): 3050
          Max Power (W): 6200
          Max RPM: 50 K
          Rm (Ohm): 0.0095
          No-load Current (A): 3.8
          Shaft Diameter (mm): 5
          Diameter X Length (mm): 39.5 X 90
          Weight: 455 g
          Pole: 4-pole
          What would be the optimal timing for this motor
          My Leopard 180a esc timing offers:
          1 - 0.00
          2 - 3.75
          3 - 7.50
          4 - 11.25
          5 - 15.00 (default timing)
          6 - 18.75
          7 - 22.50
          8 - 26.25
          I have been running default timing.
          • martin
            • 2887
            #65
            Your motor being a y wind 10-15 degrees, the default setting will be ok.
            • bayareaheli
              • Jul 2014
              • 144
              #66
              Thanks for the reply Martin will leave it default setting then.
              • Boatman10
                • Jan 2015
                • 25
                #67
                What prop are you using on that 4060? It is a 1720kv correct?
                • Boatman10
                  • Jan 2015
                  • 25
                  #68
                  I have the same motor in Mean Machine and want to get the correct prop
                  • Meniscus
                    Refuse the box exists!
                    • Jul 2008
                    • 3225
                    #69
                    Recommend removing shipping information on previous posts for obvious reasons. No reason to advertise.
                    Please also check your strut. If you find that there is excessive heat there, it could be binding. It may not be apparent by spinning the driveline by hand or testing on the bench, but once under load in the water, it could be generating too much heat. I always try to check at the conclusion of each run. I've only found the issue on one run out of the past 300 or so. It may be rare on my setups, but it is always good to check things to avoid other issues down the line.
                    Another thing that hasn't been mentioned is whether or not the motor ran hot previously. The extra heat previously could have compromised the motor and the failure wasn't triggered until a possible quick deceleration or similar such as a crash.
                    Just a few things to think about for the future, regardless of what motor you employ.
