New TP motor only a few runs shaft spun out?
Sooo... this is not good! If TP are saying (and it would be great if someone from TP can confirm) that their motors are no longer suitable for boats then I guess it's back to Leopards. From an engineering standpoint, an electric motor should be able to be stalled without the rotor spinning on the shaft. If TP have been manufacturing a product that would mechanically fail a simple stall test then they need to rethink what they are doing!
Shame, shame, shame on them!
Most companies that have good products work on improving the product, even if it costs a little more, consumers will pay for good products. Sack the idiot that came up with that plan, get it right and care for your customers, or refund them their money in full!!Comment
This would surprise me. Especially with the commitment that some have made to their products of late. I know we're just a spec of the market but still.
Plus, I'm pretty sure the guy that runs TP is a boat racer himself. He's going to produce products he can't endorse? Not likely. I'm inclined to not believe this "not for boats" claim until I hear it from them directly.
This is what I thought. ( have been having good experience with their 36xx motor)
Interesting to see what the Germans are saying, still, too early at this time to jump to conclusion. Hopefully someone will shed some light on this matter. One thing is for sure, they have changed and I wish they had held onto their older version.
If ( and I am pretty sure it is) this is a cost cutting measure to change to the present version, then TP is not alone, it is a global practice.Comment
There is also HET and NEU motors besides TP and Leopard. HET is slightly more than a TP but, far better than both TP and Leopard.Nortavlag Bulc
Agreed, we need confirmation. After all this is just one Germans' posting. It could just be there was a bad batch of rotors made.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
For those in the antipodes it can be difficult and costly to get good motors, esc's, hulls, hardware etc. There is no one stocking any good (FE) boat stuff in NZ, so you have to buy in from overseas, and the shipping really racks up the cost.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
I will shoot an email to the new owner asking if he has ran it yet..... I miss that boat.Why are you bothering me? I want to see your boat!
32" CF Rivercat--- built by "kfxguy" (SOLD)Comment
Last edited by Spartanator; 04-07-2015, 11:20 PM.Why are you bothering me? I want to see your boat!
Fastelectrics went bust, I though you had a Neu dealer there, sorry mate.
Nortavlag Bulc
Originally Posted by tlandauer
No mention if thrust bearing is used or not, my guess is that it wasn't used. That should have no bearing ( no pun intended) on this issue.
[QUOTE=bayareaheli;621796]correct no thrust bearing used.
A thrust bearing may have only delayed the issue. From what happened with the motor, it would have failed at some point or another. With all of the thrust being provided by the prop, and that thrust being transfered to the shaft and all the way up to the motor, you'll have to admit that there is a lot of force being applied to the motor. It just makes sense to remove those forces with a device designed for that purpose - a thrust washer.
Also have to make sure that the drive dog was not up tight against the strut when it was being run. The flex shortening under load will also pull on that shaft. Not sure if that question was being asked as well.Comment
[QUOTE=Quietlee;621911]Originally Posted by tlandauer
What was wierd is that I didnt notice any slippage on the previous run, and on the run where the shaft came loose I had just started a lap on the course and around the first lap around the second set of buoys I was getting back on the throttle and it was like the boat hit an instant neutral gear and stopped, I figured it will slip a bit then do that.Comment
