Castle 2028 Extreme
    • 8749
    Originally posted by oscarel
    I have, it's got a slot down the center of each sponson. I should have one in a couple weeks and I'll start a build thread.
    i'll be watching! whats so special about it? i could not find the hull online.
    • photohoward1
      • 1614
      Her you go guys: http://www.rcgroups.com/forums/showthread.php?t=2252283
      Interesting. Anybody seen the bottom on these? Worthy of another thread.
        • 8749
        thats a good idea on the ride pads thats easily duplicated.......
        I could epoxy a strip of 3mm or 4mm carbon in the inside of he ride pads, then cut a slot down the two last pads....be a worth while experiment on a cheap fiberglass hull.......
        • PowerDemon
          • 351
          Got motor and it does turn easier, not as much cogging. It's going in a new build over winter. Gonna try a new hull from CC Racing.
          [ATTACH=CONFIG]123071[/ATTACH]
          That single scoop on the left side would drive me insane.... Good looking hull though. If I ever get a big mono thats the power plant Im going to use.
            • 7990
            thats a good idea on the ride pads thats easily duplicated........
            Slotted pads have been tried for years on hydros, they proved to be very draggy. It will be interesting to see how it actually works on this cat...and how it would work without the slots.
            • meangenesracing
              • Jun 2012
              • 1167
              Very reasonable, was $200 shipped from Tower with discount.
              What discount? Do you have a code?
              • oscarel
                • Dec 2009
                • 2135
                Order Save Coupon Code
                $49 $10 410MJ
                $79 $15 410MK
                $149 $25 410ML
                $225 $35 410MM
                $289 $45 410MN
                $379 $60 410MP
                $475 $75 410MR
                $629 $100 410MT
                $719 $115 410MV
                $799 $130 410MW
                Coupon Offer Good Through Sunday, November 30.
                • electric
                  • May 2008
                  • 1744
                  I should be getting in the "new" extreme Castle 2028 in a few days. I am going to put it in a 48" mono. I might start a build thread for that one to show the progress. I have the older version of the 2028 in my Backlash Hydro and it's a great motor! Tried running it on 8s for awhile but was having trouble keeping the ESC from over heating with all the amps, but then tried 10s and the motor really started to perform with that set up. My ESC data is showing that I am running up to 29k in rpm's which is right at the 30k max listed on the old motor with no problems at all. The new Castle 2028 is rated at 45k rpm's and that should give some more head room since I will be running it 10s as well. I do see that it is now rated for 12s also hmmm.
