Has a worthy ESC been born? The Castle XLX2 looks to be an excellent ESC.
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7119
    #136
    Originally posted by donhuff
    Mic,
    In my testing, the silicone was good for about 75 psi according to my air compressor. JB Weld quick, took it up to 125 psi. It might have gone higher but that's all my air compressor will do!
    BTW, silicone tubing slides off of a nipple at about 25-30 psi, and with a zip tie to keep it on. It expands and to about 3" in diameter and then explodes at around 50-60 psi.
    I love posts that share something useful! Data is what we need more of in this hobby! Thanks Don.
    "Look good doin' it"
    See the fleet
    • donhuff
      • Dec 2014
      • 561
      #137
      Looks like we can water cool a HobbyWing ESC also.
      AmpDaddy
      don huff
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7119
        #138
        Don, have you raced those on air cooling? I have.. Q sport hydro upper 50s in Houston summer heat… not a drop of sweat.
        But the water cooler is super… cool! Nice work!
        See the fleet
        • donhuff
          • Dec 2014
          • 561
          #139
          No Jesse, I have not ever used one before. This one is a customers.
          AmpDaddy
          don huff
          • fweasel
            master of some
            • Jul 2016
            • 4290
            #140
            Saw some cool covers a guy in China made for their conversions.
            Vac-U-Tug Jr (13mph)
            • eric113
              • Sep 2011
              • 324
              #141
              Originally posted by RaceMechaniX
              Hey all,
              We are working on the X8S controller next. First samples are being machined now. I will post pics as soon as completed.
              -Tyler
              Anymore on this? I’m thinking about getting X8 for my P mono.
              • vvviivvv
                • May 2009
                • 1079
                #142
                How are these fairing with multi pole motors? normally i only have lehner motors in all my fast boats and most the ESC's i do have don't like the extra poles, but thinking to go a different route with 2x Neu 1527, 2300kv & 6s in a new SAW hull I've just become the caretaker of... Would be spinning some 45mm + 3 blades
                Uk SAW record holder
                • donhuff
                  • Dec 2014
                  • 561
                  #143
                  vvviivvv,
                  We at HuffRacing have not had any problems of any kind with our Castles. We have them in everything we race now. 4 pole 6 pole and my son has an 8 pole in his limited mono, and no problems at all.
                  AmpDaddy
                  don huff
                  • donhuff
                    • Dec 2014
                    • 561
                    #144
                    But for true SAW passes I would consider going with the larger XLX2 controller. The X8 will max out at around 300 amps, and is happier in the 270-280 range.
                    I have not found the limit of the XLX2 yet, but have heard it to be about 500 amps.
                    AmpDaddy
                    don huff
                    • RaceMechaniX
                      • Sep 2007
                      • 2831
                      #145
                      I texted with Gabe. He has been busy with other work and is trying to get back to these when time allows. The bottom plates are completed, he just needs one more op on the top cover to finish. Probably 2 more weeks.
                      Tyler Garrard
                      NAMBA 639/IMPBA 20525
                      T-Hydro @ 142.94mph former WR
                      • RaceMechaniX
                        • Sep 2007
                        • 2831
                        #146
                        Hello Liam,
                        I can tell you they are working well even with 10 pole motors at 30kRPM. That's equivalent to 300,000RPM for a 2-pole. As Don stated the X8S has a practical limit of 300A and has margin for peaks around 350A but it will start limiting at 300A for operational more than a 1 second. The XLX2 will go up to 500-550A. I found it started to clip at 550A. So for SAW passes on a 1527 go with the larger XLX2.
                        This is the XLX2 driving a 4140/5 10 pole LMT outrunner on 3S. I run this on 6S for Q mono. No problems.
                        Tyler Garrard
                        • vvviivvv
                          • May 2009
                          • 1079
                          #147
                          Hi all,
                          the XLX2 was the esc i was on about sorry for any confusion, also priced extremely well - take a AS26-XXX beautiful bit of kit but i can have 2x XLX2 for the price of one and they are readily available unlike the 6-8 months to get a hold of a AS26.
                          When i get through the backlog of current hulls that are mid build, i think ill be picking two up.
                          • eric113
                            • Sep 2011
                            • 324
                            #148
                            Sounds good. Can’t wait for Gabe have them available, it will be other great option.
                            • RaceMechaniX
                              • Sep 2007
                              • 2831
                              #149
                              Hello guys,
                              First X8S coolers arrived from Gabe at Stump Fab. Instructions have been updated. Fit is good. These should be ready to release as soon as Gabe returns from SOWEGA.
                              I used some Kapton tape to hold my cooler down after a good compression with a clamp.
                              -Tyler
                              Tyler Garrard
                              • vvviivvv
                                • May 2009
                                • 1079
                                #150
                                Are any XLX2 going to be available converted from say OSE? would like to order 2...
