Has a worthy ESC been born? The Castle XLX2 looks to be an excellent ESC.
  • TRUCKPULL
    • 2975
    #181
    I did something a little different with my XLX2's
    Question about the XLX2
    How do you tell the difference between the RX wire and the AUX wire, they are NOT marked?
    Larry
    • donhuff
      • Dec 2014
      • 561
      #182
      The cable with the white wire in it is the signal one. I take all of those out of the connector to get them out of the way. They aren't needed.
      AmpDaddy
      don huff
      • RaceMechaniX
        • Sep 2007
        • 2831
        #183
        Don,
        You want to keep the three wires closest to the end and ditch the red/white/black wires. Those are the redundant BEC power wires. Maybe the white wire is a secondary signal input, but I have always used the orange looking one.
        *EDIT*: Per the manual the white wire is for secondary control modes, like braking torque adjustment on the fly. Mostly targeting car guys. It is not a replacement for the orange colored input signal wire.
        The red and black wires are the secondary BEC current carrying wires. These are intended for applications with high BEC loads like the Xmaxx where guys are running 1100oz digital steering servo's. The second set of wires are there to reduce the stress on the primary set. You can remove them as most boaters do or you can also use them to power fans and pumps which run off the same voltage. i.e. you cannot set two different BEC voltages, just one which can be used in parallel circuits. Hopefully I am not making this more confusing.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • jkflow
          • Aug 2021
          • 329
          #184
          The white wire has the 'AUX' signal. The orange one is the standard receiver connection.
          The documentation tells you that the 'AUX' wire must be connected, that is only true if you pull the full BEC capability (20A).
          If you just have a standard servo setup and nothing crazy connected to the BEC circuit, that wire does not need to be connected.
          • TRUCKPULL
            • 2975
            #185
            On a twin setup do you have to remove one of the red wires from one of the ESC's?
            Larry
            • Panther6834
              • Apr 2020
              • 708
              #186
              Larry
              Yes...but, there's a better/smarter way. First, do NOT remove/cut a red wire on either ESC. As you'll be plugging both ESCs into a Y-connector cable, and then plugging the Y-cable into Ch2 on the Rx, remove/cut the red wire close to the ESC end, but (obviously) cute ONLY one.
              Even better, there are Y-connectors made specifically for boats that have one ESC connector with three wires, and the other ESC connector with only two.
              ~ More peace, love, laughter, & kindness would make the world a MUCH better place
              • TRUCKPULL
                • 2975
                #187
                Who ever said that these ESC's have a built in Spark Arrester circuit??
                I am running 8S and burning up my plugs every time that I plug them in.
                Larry
                • TRUCKPULL
                  • 2975
                  #188
                  What size resister would you need for an anti spark on 8S?
                  Larry
                  • RaceMechaniX
                    • Sep 2007
                    • 2831
                    #189
                    Try a 1-5 Ohm 1W resistor. https://www.mcmaster.com/1348N234/
                    Tyler Garrard
                    • TRUCKPULL
                      • 2975
                      #190
                      I just checked the resisters on my 240A swordfish HV - 4s TO 12s
                      It is 10 ohm ? on the Wattage??
                      No spark at all on 8S
                      Larry
                      • ray schrauwen
                        • 9475
                        #191
                        https://www.youtube.com/watch?v=X71Suakve6A
                        Nortavlag Bulc
                        • NativePaul
                          Greased Weasel
                          • 2761
                          #192
                          People still use Y leads?
                          I thought most running twins would be using TX mixing, especially with these, maybe i a world appart on the other side of the pond, but I can't imagine anyone running a twin XLX2 powered boat on a crappy ex RTR non computerised radio.
                          • RaceMechaniX
                            • Sep 2007
                            • 2831
                            #193
                            Paul,
                            I still run a Y-harness on my twin rigger with XLX2's with a 4PX for the simple reason that a Y-harness ensures equal signals.
                            Tyler Garrard
                            • Panther6834
                              • Apr 2020
                              • 708
                              #194
                              Originally posted by RaceMechaniX
                              Paul,
                              Exactly. Plus, NO programming needed (on the Tx). Simply program both ESCs the same (except motor directions), plug them in, and your ready to go. Couldn't be any easier.
                              • jkflow
                                • Aug 2021
                                • 329
                                #195
                                Suggest switching to QS8 connectors, they have anti-spark build in.
                                https://www.offshoreelectrics.com/pr...d=ose-qs8-anti
