The boogieman build
  • rcboatfan
    • Aug 2008
    • 253
    i found this pic i dont know if it is any help to you though
    SUPERVEE 27 37'' TWIN CAT
    • bustitup
      • Aug 2008
      • 3071
      Nice.........I really need the distance between center line of strut and rudder
      Is that a 25-27" mono?
      • knpc
        • 566
        Thats a pic of my 29'' mono. I have the same hardware layout on my df mono as well. It works great on both of them. If you want any measurements of where things are positioned let me know.
        Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
        • knpc
          • 566
          The rudder is offset 1 3/4'' from the center of the strut to the center of the rudder
          • Heath M
            • Mar 2008
            • 806
            Go for the all in one solinger mono hardware, it will great on that boat.
            Brisbane,QLD, Aussie
            • tylerm
              • Nov 2007
              • 310
              Originally posted by nate
              Were do you buy the birch at, did you cut this yourself?
              It aint birch! The wood that comes with these boats is like popsicle stick wood
              • nate
                • 1652
                Ok my bad..
                LMT
                LehnerMotorenTechnik.com
                • Jesse J
                  Former scale FE racer
                  • Aug 2008
                  • 7198
                  What flavor popsicles?
                  "Look good doin' it"
                  See the fleet
                  • ozzie-crawl
                    • Sep 2008
                    • 2865
                    my rudder is 25mm (1") from centre of stinger but my prop sticks past the rudder so it doesnt fowl. make sure when you mount your rudder it is far enough away that it wont hit the prop when turned
                    here is a picture of the back off my 25"df copy i think your hull may have the same bottom. will try and find a picture of the inside if you need one. front off motor is 130mm (5 1/4") from the back off transom esc is mounted in front of motor batteries run down the sides towards the back. i run a ammo 2300 on 4s x440 prop runs constant 45mph in the straights and full throttle around the corners very stable.
                    • bustitup
                      • Aug 2008
                      • 3071
                      lots of good info here ozzie.......sound like a nice racer..can you run in the sv27 class with this
                      or what class would it be in?
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        i dont race so not sure what class it would fall in.do you have a motor yet ?
                        ammo 2300 motor i get away with a blackjack 45amp esc
                        i would also look at the ul-1 package little less kv but being a 6 pole you could prop up as the ammo motor doesnt have a lot of torque
                        an 8xl makes these really move
                        • bustitup
                          • Aug 2008
                          • 3071
                          #27
                          Ok I knew here was a reason I was scared of the stuffing tube.....I tried bending it with m thumbs and creased it three times
                          What's the trick to bending without crimping
                          • Jesse J
                            • Aug 2008
                            • 7198
                            #28
                            Haaaaaaaaaaahahaha well you want all secrets...
                            Fill it with salt, crimp both ends with pliers (yes you need to make your tuber a little too long) and then you will not crimp it while bending. Otherwise you use a tube bender - not sure where to get these, need to ask Camel, he let me use his.
                            Try the salt or your teflon liner also warming it helps. Get extras?
                            See the fleet
                            • bustitup
                              • Aug 2008
                              • 3071
                              #29
                              progress
                              • 6S HYDRO
                                • 1320
                                #30
                                aww man why the jb weld, sorry to criticize but i think it ruins the look of the inside of a hull. why not just epoxy in?
