i found this pic i dont know if it is any help to you though
The boogieman build
Thats a pic of my 29'' mono. I have the same hardware layout on my df mono as well. It works great on both of them. If you want any measurements of where things are positioned let me know.Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine ConquestComment
my rudder is 25mm (1") from centre of stinger but my prop sticks past the rudder so it doesnt fowl. make sure when you mount your rudder it is far enough away that it wont hit the prop when turned
here is a picture of the back off my 25"df copy i think your hull may have the same bottom. will try and find a picture of the inside if you need one. front off motor is 130mm (5 1/4") from the back off transom esc is mounted in front of motor batteries run down the sides towards the back. i run a ammo 2300 on 4s x440 prop runs constant 45mph in the straights and full throttle around the corners very stable.Attached FilesComment
or what class would it be in?SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
EX President of the Offshore FE Vultures SocietyComment
i dont race so not sure what class it would fall in.do you have a motor yet ?
ammo 2300 motor i get away with a blackjack 45amp esc
i would also look at the ul-1 package little less kv but being a 6 pole you could prop up as the ammo motor doesnt have a lot of torque
an 8xl makes these really moveComment
Ok I knew here was a reason I was scared of the stuffing tube.....I tried bending it with m thumbs and creased it three times
What's the trick to bending without crimpingSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
Haaaaaaaaaaahahaha well you want all secrets...
Fill it with salt, crimp both ends with pliers (yes you need to make your tuber a little too long) and then you will not crimp it while bending. Otherwise you use a tube bender - not sure where to get these, need to ask Camel, he let me use his.
Try the salt or your teflon liner also warming it helps. Get extras?"Look good doin' it"
See the fleetComment
