Awesome info here guys....thanks so much for the responce and the help...there is so much to learn and if it wasnt for these forums there would be a lot less people into FE Boats
Titan 40 (33")
...the red titan in the picture looks real nice...seems you wernt using 2.4 digital on that correct?Yes, I was running the Spektrum 2.4 gig module in my HiTec SRX.
The main problem is most certainly not your ESC or your radio. The guy who had the boat before you never ran as fast as he said he did with that setup on 4S, period, not possible. You need a motor with a higher Kv and a larger pinion gear.
Why would you even say that?Yes, I was running the Spektrum 2.4 gig module in my HiTec SRX.
.SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
EX President of the Offshore FE Vultures SocietyComment
Oooops! Yes, I had not cut the tube on that boat when the photo was taken. Sorry.Is this better?
.Attached FilesERROR 403 - This is not the page you are looking for
A 9XL can run without the gear drive with an X445 prop on 4S easily. Your gear ratio is giving you the RPM of a 12 XL can.
Are you sure the previous owner wasn't running that motor/gear drive ratio on 6S??
You need to find a spur gear that is 50-55. Just a few teeth bigger than your pinion gear. That will get you a nice running 4S setup with a X645.
Make sure your gear lash is set correctly. There should be an ever so slight bit of play between the gears.
If you're still not getting in the 40's with this, start trouble shooting your ESC and cells.
would that 50 spur 48pinion put less stress on the motor than my 68 spur 48 pinion I have now?SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
A 48/50 gear ratio will make the motor work harder than a 48/68 gear ratio. More amps...more speed. But on 4S, the 9XL will be fine with an X645 prop.
Either go with a lower gear ratio on the 9XL or use the 7XL with the gear ratio you have.
PM me your address...I may have what I'm talking about and I'll send it to you.
Also, I like the 45 tooth pinion gear because it's the biggest gear you can have and not have to remove it from the motor to make adjustments to the motor-to-gear drive assembly, assuming you're using a Fine turbo tranny.Comment
Also, I like the 45 tooth pinion gear because it's the biggest gear you can have and not have to remove it from the motor to make adjustments to the motor-to-gear drive assembly, assuming you're using a Fine turbo tranny.SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
ok know how you have to take the turnfins and the trin tabs off the sv27 to put some caulking or sealant on the back of the harware before you remount them because they leak water
dont you have to do this with all the harware on the back of a boat...I know you get the parts lined up and drill the holes and use bolts to mount them but dont you use a caulking on the hull first before you mount the harware?
remember i'm a fast learning noooobSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
If you must, then why not silicone? I haven't done it yet, but now that you mention it, I might also. Maybe a little piece of gasket material from autoshop?"Look good doin' it"
See the fleetComment
yes yes yes that's what I was referring to "silly cone"
thanks brother J...you know you have been so nice to me that its really really going to hurt to crush you so badly when we post are gps readings BWAHAHAHAHAHASPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
I'll still be nice when I post my larger than thou super-speed readings... But I really can't wait to see your video of this and the long-legs of the Viva Miss Vegas struttin her stuff also!"Look good doin' it"
So I just got mine and it has a shortened strut, 2" instead of 3". Is there a reason for this? I was recommended to shorten the one on my DF26, but just noticed that yours is longer than mine. Not to be envious, but I was thinking that these longer hulls would need a full 3" strut? am I being goofy or should I get me an extended strut?"Look good doin' it"
