38" H&M Intruder twin to begin
  • Jesse J
    Former scale FE racer
    • Aug 2008
    • 7198
    #136
    Originally posted by Peter Zicha
    Man thats beautious Jesse.............thanks
    the Aluminum for the plates I won't be able to get till Saturday and thats hoping they have 1/16
    At your service! if you don't get the 1/16" no worry, just if it doesn't slow you down or cause any extra bourbon.
    "Look good doin' it"
    See the fleet
    • Punisher 67
      Ignore list member #67
      • May 2008
      • 1481
      #137
      Jesse your fronts are machined , your rears are being redone right now . as you can see the reliefs are out way to far . Your fronts have 16 holes for the motor giving you maximum flexibility
      Necessity is the mother of invention.............
      Youtube Video's http://www.youtube.com/user/Titanis2000
      • Jesse J
        • Aug 2008
        • 7198
        #138
        YOU ROCK, MAN. Just got word (werd.) from the Egneg that my props are on their rockin way, and before long I will be pooling epoxy around my stuffers - indicating that the motors are successfully mounted and thhhhhheeeennnnnnnnnnnnnnnnnnnnnnnnn -- for the roost of all roosts
        See the fleet
        • bustitup
          • Aug 2008
          • 3071
          #139
          even i am getting excited
          • Punisher 67
            • May 2008
            • 1481
            #140
            Jesse
            Do you want the mount holes on the bottom the same way threaded 8/32 or how do you want them
            • Jesse J
              • Aug 2008
              • 7198
              #141
              Right, yes same way, but how about 6/32? don't need quite that massive of bolts, thanks for asking.
              See the fleet
              • Punisher 67
                • May 2008
                • 1481
                #142
                I might also be able to get 1/16 Aluminum in town here some of the hardware stores sell it small strips up to an inch wide
                Give me the exact dimensions you need 1/16 x length x width
                • Jesse J
                  • Aug 2008
                  • 7198
                  #143
                  2 @ 3.5" and 2@ 2.5" by 5/8" wide, and thanks again-again.
                  See the fleet
                  • Punisher 67
                    • May 2008
                    • 1481
                    #144
                    1st rear correction finished the second is milling right now , you can see the difference
                    I will also see what I can find in 1/16 Alum Jesse
                    • Jesse J
                      • Aug 2008
                      • 7198
                      #145
                      I like, I send you some $$ to help you out!
                      See the fleet
                      • Punisher 67
                        • May 2008
                        • 1481
                        #146
                        Jesse I appreciate you sending that , it will certainly cover some costs but don't send any more , I will take it from here I want to see this succeed as much as you do . I really felt bad when it didn't come together for you the last time . I have to either make or find a mock 1515 to get the precise angle to trim the bottoms but no worries I have some idea's . This will most likely be send out either Mon or Tues and hopefully I can find some 1/16 here in town....Have a few leads there also...................
                        • Jesse J
                          • Aug 2008
                          • 7198
                          #147
                          Peter, I had a suspicion you would have felt bad, but this is a team design and the players are in different countries, I would have been quite surprised if it had fit perfectly the first time! I appreciate your dedication to this and am sure it will work this time.
                          Do you want some super precise motor measurements and the cooler can as well? If possible I would like to use the coolers, but really probably wont need em.
                          Thanks again Peter!!!
                          See the fleet
                          • Punisher 67
                            • May 2008
                            • 1481
                            #148
                            Sure sent the measurements , I am still going to build a mock motor to get the exact angle of deflection
                            thanks Jesse
                            • Jesse J
                              • Aug 2008
                              • 7198
                              #149
                              motor: 2.685" long by 1.535" across
                              can: 2.190" long by 1.890" across (with nipple: 2.230")
                              anything else that might help? lemme know.
                              thanks Peter
                              See the fleet
                              • Punisher 67
                                • May 2008
                                • 1481
                                #150
                                Thanks for the measurements , now to go make the fake motor...............
                                Oh BTW I did manage to find 1/16 x 3/4 x 6 foot flat bar in town so we are stylin there also
