47inch cat 3d print build
  • Bande1
    • Mar 2023
    • 680
    jees if you come to ohio Id give you a bunch of hulls I cant get rid of them. zippkits boats are only like $89.
    • Alfa Spirit
      • 2131
      Interesting, But is not a printed made hull too fragile?
      • keesey
        • Feb 2025
        • 99
        depends how its structured and assembled, i plan on finishing in carbon fiber potentially or some sort of other marine rated finish. i can stand on my sponsons and they have zero deflection and or cracking from my body weight.
        • Alfa Spirit
          • 2131
          The carbon is very light but the epoxy is lead...
          • keesey
            • Feb 2025
            • 99
            Time to start the finishing, going o get the hull straight then weight it to see what I want to do. Carbon/kevlar most likely
            • keesey
              • Feb 2025
              • 99
              Some flexible filler and primer, ready for another coat of filler now that I have some contrast. And can see the low spots better by being grey after a light sanding.
              • keesey
                • Feb 2025
                • 99
                Block sanding and dry guide coat, flexible bumper filler.
                First coat of high build primer then some light sanding.
                Second coat of primer and starting to fit the cowl
                Probly do two scoops instead of one, I think it looks better plus the boats going to have twins.
                • keesey
                  • Feb 2025
                  • 99
                  #23
                  Started making templates for the inlay in the motor compartment. Planning on carbon Kevlar twill as I like the lighter color.
                  • steve55340
                    • Apr 2019
                    • 10
                    #24
                    Hi Keesey. Glad to see another 3D printed hull. I printed a 72" cat that I'm working on now (16 pcs for hull, 10 pcs for hatch). I'm in the process of prepping for paint. Using automotive body filler but very unhappy with the way it is working. The stuff is super difficult to sand smooth - waited too long and it basically polished (80 grit paper) so tried sanding after a few hours and really wasn't much better. Loads up my sandpaper right away.
                    What did you use for filler? Any tips to make this go better for me? Looking for threads that may tell me how to do this. Must still be guys who need to do bodywork on their builds?
                    Good luck on your boat - I'll be following you along!
                    • keesey
                      • Feb 2025
                      • 99
                      #25
                      I used a flexible bumper filler, wasn?t cheap by any means, but sands super nice.
