Slow build - 8S Twin Cat
  • photohoward1
    • 1610
    #31
    Hopefully we can get together this year larry. I have competition for you!
    Originally posted by TRUCKPULL
    Hello Alain
    I am not sure what OFNI is,
    But yes 2 X 56106 TP motors, 1,066m Cat, 8S- 6000 mHa per motor.
    This is for racing in IMPBA S+T or Open Cat, or Open Hydro classes.
    Larry
    • Alfa Spirit
      • 2131
      #32
      Hello Alain
      Larry
      In english OFNI is "unidentified floating object" ...
      • TRUCKPULL
        • 2969
        #33
        Larry
        • TRUCKPULL
          • 2969
          #34
          Howard
          It will be fun. What you got?
          Larry
          • jaike5
            • Dec 2011
            • 561
            #35
            Photohoward1, ....how about a photo, Howard !!
            J.
            • photohoward1
              • 1610
              #36
              Big Singles.....
              Howard
              Larry
              • TRUCKPULL
                • 2969
                #37
                Big Singles.....
                Three or four big singles in one boat?
                • TRUCKPULL
                  • 2969
                  #38
                  Well I got my package from OSE this morning.
                  In the mean time I have been busy, I filled all the holes on the hull. A crack in the joint on the
                  inside of both sponsons, The window area was damaged by a flip at over 70 MPH three years ago.
                  I reinforced it with Carbon Fiber, sanded it all down,, applied Epoxy with Micro Balloons.
                  Then sanded - sanded - and sanded again. then wet sanded the hole thing.
                  I also installed two hatch locks at the rear of the hatch.
                  It is now ready for primer.
                  Sponsons bottom edges were sharpened and blue printed also.
                  Larry
                  • Alfa Spirit
                    • 2131
                    #39
                    Hello Alain
                    Larry
                    Hi Larry,
                    OFNI means Unidentified Floating Object in french and UFO in english ...
                    • TRUCKPULL
                      • 2969
                      #40
                      I got my two water pumps installed, These are flow through pumps,
                      This means that when the water flow is higher then the output of the pump, It flows with no restriction.
                      The flow on these little pumps is over 1 US Gal per minute.
                      There draw is only 0.400 A, so for the two of them is only 0.8A
                      To power these I use a
                      This will take up to a 36V input - with a 12V at 2.2A output.
                      I ran two of these pumps in my 6S twin all last year with no problems.
                      Last fall I put one of these pumps in my humidifier it has been running steady for six months now with No problems.
                      • TRUCKPULL
                        • 2969
                        #41
                        I installed two 1/4" X1/4" carbon square tubes
                        along the top of the inside bottom at 5 1/2" apart
                        This will add some rigidity and align my servo mount plate and my ESC mounts.
                        The Push -Pull system, Is made up of two HS5645MG Digital servos.
                        When placed facing each other, servos will always work opposite to each other.
                        Larry
                        • Jesse J
                          scale FE racer
                          • Aug 2008
                          • 7119
                          #42
                          I hope you didn?t glue in the ballast, Larry; me thinks you won?t need it!
                          "Look good doin' it"
                          See the fleet
                          • TRUCKPULL
                            • 2969
                            #43
                            Jesse The lead blocks and the mag-blocks, were just to hold them down untill the JB dried.
                            I had drilled each rail with a 3/32" drill, every 3/16" for the total length, to get the JB into them.
                            If it is too heavy when I am done, I will use balloons, with helium in them for floatation.
                            Larry
                            • Jesse J
                              scale FE racer
                              • Aug 2008
                              • 7119
                              #44
                              Thanks, buddy, that makes me feel better!
                              See the fleet
                              • TRUCKPULL
                                • 2969
                                #45
                                This Cat is 41 1/2" from transom to the tips.
                                From the tips to the props is 46"
                                This boat is no feather weight by any means, Right now I am pushing 22LB ready to run.
                                What should my CG be? I am thinking 13.5" to 15" from the rear.
                                Larry
