Slow build - 8S Twin Cat
  • fweasel
    master of some
    • Jul 2016
    • 4286
    Clever minds think alike. I turned a similar alignment tool out of Delrin on my lathe to help me align the motors mounts before epoxying them into place.
    Vac-U-Tug Jr (13mph)
    • TRUCKPULL
      • 2969
      Before epoxying in the motor mounts, I made sure that the two drive tube were the exact same length.
      I also epoxied in the drive tube alinement holder.
      Seeing that I could only put epoxy on the front side on the first go, then let set up for 24 hours.
      Second mount same thing front side - 24 hours
      Then I could stand the boat on the tips and do the back side of both mounts, and the drive tube alinement holders - 24 hours
      I use West Systems 105 Epoxy, and 206 Slow Hardener, with Fumed Silica
      Larry
      • TRUCKPULL
        • 2969
        Here is what my power system looks like.
        Tp- 5670 - 1180KV - 6D
        I also drilled and taped new holes for the water inputs on the motor coolers,
        so the exit would still be at the top of the cooler.
        You will also notice that the coolers are now Left and Right.
        The original holes were plugged with stainless 6mm screws and Loctite.
        Larry
        • TRUCKPULL
          • 2969
          I forgot to mention,
          When I did the Carbon Fiber Inlay,
          I also added 2mm Carbon Fiber plate to the inside of the transom.
          Larry
          • ray schrauwen
            • 9472
            Looks good Larry. Do you do al that at the condo or somewhere else?
            Nortavlag Bulc
            • TRUCKPULL
              • 2969
              The second bedroom is my Computer and workshop here in the Condo.
              There is also a workshop downstairs on the main floor, with an exhaust fan that I use for grinding, sanding, and painting.
              My lath, Mill, band saw. drill press, pedestal grinder, ETC are set up at my son's house.
              Larry
              • ray schrauwen
                • 9472
                NICE!
                I'm building a baby twin compared to that monster. 28" Pathfinder. Barely started but it's cleaned out ready for Carbon Kevlar... Unless you have some leftover CF cloth you might sell me again?
                Looking for a piece about 15" x 22" or longer.
                Cheers!
                Nortavlag Bulc
                • ray schrauwen
                  • 9472
                  #23
                  26" max L
                  Nortavlag Bulc
                  • TRUCKPULL
                    • 2969
                    #24
                    26" max L
                    Carbon Fiber - I have, I got a couple yards at Noah's when I was their.
                    Larry
                    • TRUCKPULL
                      • 2969
                      #25
                      I installed the motors using the Three 4mm screws in the front of the motors,
                      so I could align the base for the tail ring mounts, and epoxy them into place.
                      After they dried. I removed the motors to put more epoxy on the front side.
                      Larry
                      • TRUCKPULL
                        • 2969
                        #26
                        Right now this is my proposed layout.
                        I am in waiting for an order from OSE for my Carbon ESC mounts and battery trays.
                        Larry
                        • ray schrauwen
                          • 9472
                          #27
                          Looks good Larry!
                          You're a lot faster than me!
                          Nortavlag Bulc
                            • 7673
                            #28
                            Gonna be a great boat Larry! Happy holidays to you.
                            NICE!
                            Cheers!
                            Ray your making me miss my Geico twin
                            • Alfa Spirit
                              • 2131
                              #29
                              This is an OFNI, 2 x 56106 in a 1,06m. cat
                              • TRUCKPULL
                                • 2969
                                #30
                                Hello Alain
                                I am not sure what OFNI is,
                                But yes 2 X 56106 TP motors, 1,066m Cat, 8S- 6000 mAh per motor.
                                This is for racing in IMPBA S+T or Open Cat, or Open Hydro classes.
                                Larry
