32 inch F1 Tunnel build: Cozy F1 T800
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    #46
    Wow, great running boat! Looks super responsive.
    Would you consider sharing your plans?
    "Look good doin' it"
    See the fleet
    • Dirk Jan
      • 167
      #47
      Thanks Jesse [emoji106]. I will share the plans, but I need to update the drawings still.
      • Dirk Jan
        • 167
        #48
        I'm fine tuning the setup and I gained some speed by adjusting the outboard leg with a little more positive angle and also set it a bit higher.
        The T800 ran a little too loose, as can be seen in the short video. Top speed is 55mph with 443 prop, 6S and 1650kv 3674 motor.
        Now, for everyone who wants to build a Cozy F1 T800, I share the plans for free. See attachments. Drawings are A1 size. It took me quite some work.. all I ask is not to use the design commercially.
        If you build one, please show me the result [emoji3]
        Cozy_F1_800_assembly_drawing.pdfCozy_F1_T800_mid-section_drawing2.pdfCozy_F1_T800_mid-section_drawing.pdfCozy_F1_800_sponsons_drawing.pdfT800_cowl_drawing.pdf
        • Jesse J
          scale FE racer
          • Aug 2008
          • 7128
          #49
          This is great, thanks for sharing Dirk!
          See the fleet
          • Dirk Jan
            • 167
            #50
            Yesterday I ran 2 lipo's through the Cozy F1 T800. After 12 runs, the hull and outboard hold up well.
            Top speed is 57mph so far, with 643 prop. I'm still fine-tuning the setup. I think with the prop set a little higher, it could go faster. I'm shooting for 62mph (100 km/h).
            The hull is really stable, even when pushed a little harder. Here's a video of yesterday's run:
            • ShaneDowdy
              • May 2022
              • 1
              #51
              Are you still using the mini tfl outboard for this boat? It looks like the mini leg. Would it be more beneficial to use the larger version for this boat?
              • Dirk Jan
                • 167
                #52
                This is a 33" hull with 6S power and it does use the TFL large leg.
                • Dirk Jan
                  • 167
                  #53
                  Last weekend I took the T800 to the pond again. Running a 44mm 1.6 pitch prop I got to 60mph.
                  It was quite windy and the hull was running a bit too loose in these conditions. Carefully against the wind..
                  Here's a video of last weekend. I flipped the hull twice. The hull holds up quite well, but I destroyed 2 steering servos already.
                  Esc is a Turnigy Marine 120A. Holding up surprisingly well. At least for the fun boating I do [emoji3]
                  • autolex
                    • Sep 2021
                    • 84
                    #54
                    I never tire or seeing the beautiful Cozy F1 T800 running Dirk!
                    do you have any ideas why you're going through servos so quickly? what make/model are you using?
                    now you have me thinking: i have a small catamaran hull that i have some "prop-ride" issues with (It's way overpowered and overpropped) but has me thinking about a gyroscopic tethered throttle (mounted 90? from normal) so when the hull pitches up the gyro could pull throttle... hmmmmm.
                    MHZ Mystic 84 (BUILD) | DYMotorshop 750mm Mono (BUILD) | BlackJack 24 of Theseus (54mph) | ProBoat JetJam (toy) (BUILD) | Noodle Recovery Scaffolding (6.6mph)
                    • Dirk Jan
                      • 167
                      #55
                      Thank you Autolex [emoji106]
                      The servos broke due to flipping the hull. The impact on the outboard of a bad landing, stripped the gears. Due to that, one servo motor burned down.
                      Both servos were metal geared, digital and with metal casing. First one was a HK servo, second one a Savox [emoji51]. I might be able to fix the Savox, if I can find the gears for reasonable price.
                      The gyro idea is really nice! If it works, it might be a quick return of investment [emoji28]. I will think about applying it.
                      • Dirk Jan
                        • 167
                        #56
                        Here's a slide show video of my 33" F1 tunnel construction. For your entertainment and maybe pick up some ideas for your next builds!
                        • Dirk Jan
                          • 167
                          #57
                          It has been a while since I updated this topic. Last April a big catamaran collided into the T800 tunnel. It broke the cowl in half and the radio box at the front crushed.
                          I'm now repairing the damage and I made a video of it:
                          • autolex
                            • Sep 2021
                            • 84
                            #58
                            whoa! that wasnt very nice of the other vessel driver, especially to a nicely finished boat like this!
                            Look forward to your rework!
                            • Dirk Jan
                              • 167
                              #59
                              It was very unfortunate and the catamaran owner felt really bad about it. He paid me for the repair as well. No hard feelings towards him. It was just an accident [emoji41]
                              • Dirk Jan
                                • 167
                                #60
                                I ran my 33" F1 T800 together with a mono boat. 2 different boats, with different power setups. But pretty well matched!
                                Arrow Shark mono:
                                Length 35"
                                6S 6200mAh
                                4074 2000kV
                                Flycolor 150A
                                43mm 1.6 prop
                                Weight ca 3500 gr.
                                Cozy F1 T800:
                                Length 33"
                                6S 5200mAh
                                3674 1650kV
                                Turnigy Marine 120A
                                43mm 1.6 prop
                                Weight ca 3100 gr.
                                The mono has more power, but the top speed yesterday was exactly the same: 54mph.
