32 inch F1 Tunnel build: Cozy F1 T800
  • autolex
    • Sep 2021
    • 84
    BEAUTIFUL woodwork! I can definitely say i'm not this talented (or patient!) keep up the pictures!
    MHZ Mystic 84 (BUILD) | DYMotorshop 750mm Mono (BUILD) | BlackJack 24 of Theseus (54mph) | ProBoat JetJam (toy) (BUILD) | Noodle Recovery Scaffolding (6.6mph)
    • Dirk Jan
      • 167
      Thank you Autolex [emoji106]
      Next update:
      Filling the sponsons with foam board.
      I made a template from paper for the deck plating.
      The deck is from 0.8mm birch plywood. I managed to apply the deck in one piece.
      I chose for the SSS 3674 1650kV motor; it is affordable and I heard good stories about SSS motors.
      Verstuurd vanaf mijn SM-G970F met Tapatalk
      • lilbigmacky
        • May 2020
        • 26
        Looking great so far. Do you have cowling for the outboard motor?
        • Dirk Jan
          • 167
          Yes, cowling will be home made, for outboard as well as the main cowl/ cockpit and it will be shown here lateron!
          • Dirk Jan
            • 167
            Another update, starting with a comparison between the Cozy F1 and Cozy F1 T800
            Bottom side with lowered mid section:
            Time for applying laminate, 50gr/m2 glass cloth. I used the deck template again.
            • nocebo
              • Jun 2020
              • 79
              This is awesome! Really amazing work and cool to see it go from a concept to reality.
              A question on your inventor modeling process - do you start my modelling the overall shape/profile of the hull and then later build out the framing? What do you use as your reference for sizing of various hull components?
              • Dirk Jan
                • 167
                Thanks Nocebo and good question about the design.
                I used the actual F1 Tunnels as reference and I took a good look at rc F1 Tunnels for the length - width - height ratio.
                As I made the smaller Cozy F1 already, I took that experience as well. For example, I wanted wider sponson ride pads with less angle, to improve cornering. Also, I wanted the sponsons and deck smoothly transition into each other. That's why I started the design with a sketch of the transom, including sponsons. Next I made a mid plane and sketched the deck layout from the top. Next, the actual sponsons and deck were designed separately from the main sketch as reference.
                • Dirk Jan
                  • 167
                  #23
                  Next update; I designed the cockpit / cowl in 3D CAD. I will make a mold with wooden ribs and foam in between. On top of the mold I will directly make the cowl from carbon fiber.
                  Finishing the front-mid section:
                  Installing the Turnigy 120A Marine esc. It is positioned besides and below the steering servo. I made a support from ply and mounted the esc with double sided tape.
                  As the mid box is very large, I put a cross bar between the lipo and other electronics. The lipo is a 6S, 4500mAh 60C.
                  The hull so far, including steering linkages.
                    • 7673
                    #24
                    Beautiful work
                    • nocebo
                      • Jun 2020
                      • 79
                      #25
                      Ahh i understand, Im assuming you then sliced the solid to create individual sketches for parts for the framing members? Been thinking about doing a design for a while, but every time i sit down with a blank sketch in Inventor, I dont know where to start. You've done awesome work, looking forward to seeing it run.
                      • Dirk Jan
                        • 167
                        #26
                        Thank you guys [emoji106]
                        @Nocebo: I didn't design the hull as a solid, but I used sketches in planes and also used 3D sketched lines for the sponson sides for example.
                        I started with the transom, including sponsons and added the lines for the length of the sponsons as well:
                        Added the shape of the hull-mid section:
                        I made a solid for the sponson sides and I added 3D sketched lines for the sponson shape:
                        Added the ribs between the 3D sketched lines and made them as separate parts:
                        Built the mid section of the hull from the sponson lines and bottom sketch:
                        Finally, assembled it all together to make the design complete. Of course it took me a lot of fine tuning and modification to get the hull shape to my liking.
                        I hope it helps you making a start on a hull design. You could also design a solid like you said; there are many ways!
                        • Dirk Jan
                          • 167
                          #27
                          Complete hull:
                          • nocebo
                            • Jun 2020
                            • 79
                            #28
                            Thankyou so much, this is exactly what i was looking for. Youve done a great job on these models, they look really clean and neat.
                            Ill give it a go following your method - might have to start with a small mono first though, a bit easier : )
                            • Dirk Jan
                              • 167
                              #29
                              Here's the next update.
                              I made the battery tray from birch plywood and laminated both sides.
                              Preparing the hull for paint:
                              Starting the paint:
                              I started with the cowl mold as well:
                              • Dirk Jan
                                • 167
                                #30
                                Finishing the paint on the hull:
                                And finishing the mold for the cowl:
                                I laminated 2 layers of 200gr/m2 carbon fiber cloth and 1 layer 50gr/m2 glass cloth to finish it smoothly.
                                I put a non-carbon part in, for receiving the transmitter signal and gps signal.
                                Before laminating, I waxed the mold and applied PVA film.
                                The cowl released from the mold without issues:
