Zippkits jae 21fe v2 outrigger_wood kit build
  • sammyha
    • Jul 2018
    • 1037
    #196
    Originally posted by Bande1
    7709 / 209 = 36.88v
    thats not right. 10s?
    The SMC HCL/HV lipos are 4.35 volts/ cell fully charged. Have to have an LiHv capable charger
    • sammyha
      • Jul 2018
      • 1037
      #197
      That's 34.8 volts fully charged for 8s
      • sammyha
        • Jul 2018
        • 1037
        #198
        7709 / 209 = 36.88v
        34.8 volts fully charged... and that's still not right
        7705/209= 36.86
        I just looked at the max numbers from all the runs on the Data Log. Not individual graph numbers that match up with each other, if that makes sense...
        • NeverEnuff
          • Jul 2011
          • 19
          #199
          Sam, you can zoom in on the portion of the data that is just the speed run and the Castle Link Graph Viewer software will post just the max, min and average values for that time period. Here is an example of data from my JAE 21 92 mph pass.
          • sammyha
            • Jul 2018
            • 1037
            #200
            I've cleared it out already. Next time out I'll do one pass and check the numbers...
            • Notoriousone
              • Oct 2022
              • 65
              #201
              Congrats on the 119mph pass Sam, that's awesome.. I'm impressed that the TP motor you had in there with over 2500kv didn't blow on 8s! Your making me want to get my JAE 33 out, switch out the motor and esc and try to put up some numbers with it
              • sammyha
                • Jul 2018
                • 1037
                #202
                Thank you sir! It's listed as an 8s motor. Or I never would have pushed it that hard. For sure it's super exciting to run that fast. Got to have everything right. Get out there and lay one down!
                • sammyha
                  • Jul 2018
                  • 1037
                  #203
                  I put together a video of SAW runs to show what fast passes compared to truly fast passes look like...
                  • leski379
                    • Jul 2023
                    • 93
                    #204
                    Just realized your the guy from youtube.... Great to see the boat even more in depth and also congrats
                    • sammyha
                      • Jul 2018
                      • 1037
                      #205
                      Thank you!
                      I'm trying to put the setup info together and share it, so others don't have to piece it together like I did. But now it's scattered in multiple videos I've posted on YouTube. [emoji2955]
                      And I'm realizing it also takes know how you can only get thru experience.
                      I appreciate the timely tips from so many guys here on the forum and from comments on my channel as I was learning.
                      It can't hurt to put the info out there. Unless you're keeping secrets to be the fastest, lol.
                      I love to see others succeed too...
                      • fweasel
                        master of some
                        • Jul 2016
                        • 4285
                        #206
                        that is smokin fast. Congrats on the results from all your hard work.
                        • sammyha
                          • Jul 2018
                          • 1037
                          #207
                          Thank you! Yes, putting in the time. Looking back, I see there's no other way...
                          • Bande1
                            • Mar 2023
                            • 684
                            #208
                            yep keep it coming sam!
                            • sammyha
                              • Jul 2018
                              • 1037
                              #209
                              New Personal Best SAW run for me. This setup is running so good...
                              • sammyha
                                • Jul 2018
                                • 1037
                                #210
                                I've dug into the Castle Data Log a bit. New thing for me. Here's a screenshot of the current and the watts...
