Thundercat 31 conversion build
  • m4a1usr
    Fast Electric Addict
    • 2038
    #136
    Originally posted by lomdel
    John, isn't the 1050kv of the 1521 1,5Y a bit low on 6S? You sure you get 50+ mph with this motor on 6S in a TC31 hull with a 225 prop?
    Runs great on 6s with a 1050kv motor. RPM's a little over 23k the entire run, eagle tree has it at 80amps average with some 105 spikes in the turns. A 225 is what I decided runs the best. My Geko 201 puts the peak speed at just over 58 mph but we all know GPS lies to our faces. It wasnt until I had a couple bouys out and used help and stop watches that I could get the speed acurately. Typical straight way speed slightly over 50 mph. A Prather 225 is a 48mm dia prop with a 2.8 pitch. Plenty of prop for this size hull. I've run this hull with many combinations from 1445, a x447, even went up to a prather 230, then even tried my specialy mod'd props like texas cuts in various diameters. Top speed moves about but so do the other issues, heat/run time/stability. The key to getting this hull right is strut depth/ rudder length/ COB just in the right spot. I even modified a ABC 50/90-3 for giggles specificly for this hull. It ran pretty darn fast but the amps were way over my speedo I like in this hull. I use a Sentilon HV 100A. Been running the same speedo now for more then 2 years.
    I took some very basic advice from Jay Turner a couple years ago. He made it very clear that perfecting your setup and not throwing away the power you already have in your setup gets you much further then you may think. I bet I am overpowering this hull with a 1521. Wasted power most likely!
    Sorry to hear about your crash. I have been lucky and never lost a boat due parts failure. Fire yes! What a heart sinking feeling to see your labor/ money sink to the bottom. I feel your pain.
    John
    Change is the one Constant
    • lomdel
      • Nov 2008
      • 708
      #137
      Some pics of the crash damage! Could rescue all electronics to working condition except the servo... Is this damage repairable or would you guys advise me to purchase a new hull?
      • elvish
        • 125
        #138
        how much does the new hull costs?
        • Darin Jordan
          • 8335
          #139
          $179.99
          Darin E. Jordan - Renton, WA
          • elvish
            • 125
            #140
            I love repairing, but that crash looks nasty, I would buy a new hull (my opinion)
            • lectriglide
              • 538
              #141
              OOOUUUUCCCCHHHHHH!
              How about a Mean Machine hull for $60 @ Aeromarine? The two hulls actually look very similar, not sure about the dimensions or hull quality though. Might be worth a look.
              • m4a1usr
                • 2038
                #142
                Damn Dawg. That was full speed ahead! Damn the torpedos. I vote for replacement too. But I wont bad mouth the T/C hull. It would have looked far worse if you had used cheaper Chi stuff. I have owned a MM that ran decent but I dont think the seams are as beefy as a T/C. They are tanks and not the lightest layups. But strong.
                John
                  • 9488
                  #143
                  Originally posted by m4a1usr
                  Get a Neu motor dont settle for less. I have been running a TC31 FE conversion for a couple years and running the right motor makes all the difference. I settled on a 1521 1.5Y and its got all the power you can need for sport running. A prather 225 and you will be well over 50mph. With temps barely warm on all the important parts.
                  John
                  wow, lots of power with that setup!
                  • lomdel
                    • Nov 2008
                    • 708
                    #144
                    Well, I plan to revive the beast before our summer here in the southern hemisphere. But it seems that all the suppliers of the TC31 hull only (PRB2765) are out of stock! I would like to use a TC31 hull again due to the custom made motor mounts and other hardware and a proven set-up that I acheived after much trial and error. Any tips on where to buy/order a new TC31 hull?
                    • lomdel
                      • Nov 2008
                      • 708
                      #145
                      New TC31 hull ordered and on its way!! The (Thunder)Cat will roar once again...!! Whatch this space. Can't wait to get her on the water again. This time with a 12XL on 6S lipos through a S215 prop...
                      • lomdel
                        • Nov 2008
                        • 708
                        #146
                        The cat is alive again... http://www.facebook.com/photo.php?pi...00000145525723 !!
                        • forescott
                          Hopelessly Addicted to RC
                          • 2686
                          #147
                          Cool! An old thread resurrected!!
                          • lomdel
                            • Nov 2008
                            • 708
                            #148
                            Some (cellphone) pics of the current status of the new hull...
                            • lomdel
                              • Nov 2008
                              • 708
                              #149
                              Just had her out for her first outing since the rebuild. She ran like a cat on a hot tin roof! Beautiful!! But on pass #6 I miscalculated the location of a small island in the loch and flipped her... No damage to the inards or the boat itself, only my ego... I had a RC friend of mine with and he just happened to take a short video clip of the roll. We'll try to get it posted as soon as possible. I ran her only with the sub-hatch installed without the canopy.
                              • lomdel
                                • Nov 2008
                                • 708
                                #150
                                The clip at http://www.youtube.com/watch?v=4IDL26HuUag ... Excuse my language at the end!
