HPR 115(Average White Boat)
Ok well I got the rudder all mounted. As you can see in the previous pic of the drives the rudder mount holes are not really proper/square/centered. So I decided to go with the epoxied tube method of mounting the rudder bolts.
I cut four lengths of tube for the 25mm bolts to run thru, drilled the rudder holes a size over,assembled it all, and poured epoxy into the rudder extension to hold it all together.Comment
Along the way here I found my supplied motor mount a tad off for my application so I enlisted Jeff(monojeff) to punch me out a couple new ones. These should be here this next week.
The only thing left that I could do at this point is work up some water inlet tubes and drill those holes in the bottom of the hull.
All I can do at this point is tape them in as these tubes may be running thru the motor mounts as support but you guys should get the jist
And that is where I am at now. Alot of double checking my CG so I can get my necessary adjustments.Comment
Puuuurrrtyyyy!Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Crafty are we. Is it the same Tubing you use for water pickups?Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
