MHZ 114 High End Build
A few more to show the enter/exit hole, and the very clean alignment of the drive housing
IMG_1211.jpgIMG_1212.jpgIMG_1214.jpgIMG_1215.jpgIMG_1216.jpgLast edited by nata2run; 03-04-2015, 01:00 AM.Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
"Follow someone's footsteps and you will always be a step behind"Comment
Awesome, man! Very professional work there. Even the masking tape trick alone is a great one to take from this thread. Never thought of doing that, makes a lot of sense to layer it up to keep the gelcoat from cracking.Comment
Wow Kent, this is like deja-vu. It's like watching my own MHZ Mystic 114 coming together. I have been taking photo's of every stage just like you. I'll have to get round to starting a build thread. Then folks can watch how are builds are progressing and see how we diverge when it comes to the internal fit out.
People maybe interested to know that my component list is a little different:
Motors: LMT 2240/8
ESC's: MGM 28026-3 X2 Series Pro
The rest is pretty much the same with the motor mounts heading towards me from Custom Carbon Fiber Parts in OZ. Kent made them for me with a little visual design feature …….. all will be revealed later !!!
I'll keep you'll posted as things progress.Comment
Hey Steve,
You should do a thread! would be interesting to see what you have come up with, I'm sure it would look great!
Ok, back to the build. I am forever trying to find the best way to get the drives aligned. This may not be the easiest or best way, but its so far the most accurate way I can think of. The ole "drill bit trick from Manuel W. still tops it off as a final alignment" But the "drive hold down's" are still made in a way on the MHZ's that make it complicated to place on the hull and use as a template. For that reason I made my own block that can sit flush on the hull and allow me to drill the 4 holes to hold it down further.
IMG_1220.jpgIMG_1221.jpgIMG_1223.jpgIMG_1224.jpgIMG_1225.jpgVisit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
Here are all the blocks used...
After everything was aligned and the 4 holes were drilled, I used the 2nd block as a drill guide. This block was stuck down with double sided tape and also the 4 screws through the block. ( I didn't bolt down the block, just used to screws to hold the block in place)
IMG_1230.jpgIMG_1231.jpgIMG_1233.jpgVisit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
When all secured, I just drilled the hole with a 14.5mm NEW drill bit. I'm quite happy with the result.
IMG_1235.jpgIMG_1241.jpgIMG_1264.jpgIMG_1265.jpgVisit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
I'm finding less and less time to post and upload pictures of this build. But I thought I'd keep you in the loop of whats going on. I had to completely redesign the motor mounts for this particular build, as I want to use CF veneer for decor also. I have so far made 3 different versions and not 100% happybut good news is, I think I got it!! once installed, I will post some photos. After that stage she will go straight to the painters....
Kent, do you take the hardware off when you send it to the painters?
I'm also building an mhz 114. Does your rudder bracket fit onto the hull? Mine doesn't want to slide into the cut-out area which seems to have too much gel coat. What do you recommend to shave off some of the material precisely?Comment
I'm also building an mhz 114. Does your rudder bracket fit onto the hull? Mine doesn't want to slide into the cut-out area which seems to have too much gel coat. What do you recommend to shave off some of the material precisely?Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
Thanks for the compliments! No, not a tool or mold maker, but a graphic designer and graphics instructor for the past 20 years. Not teaching anymore thou, but have my own visual display/sign shop as an everyday occupation. I guess if I can think of it, I can make it :)Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
Got a bit more work done the other night. Instead of using just plain washers where the drives mount to the hull, I decided to install a support plate. It's commonly used in builds like this, but I haven't done my builds this way prior. The reason why I'm using it this time around is because I really want some support on the stuffing tube in that end. I think it came out nice and serves the purpose. I also got the motor mounts cut and will be posting the update a little later when I complete the inlay.
IMG_1214.jpgIMG_1293.jpgIMG_1294.jpgIMG_1295.jpgIMG_1297.jpgVisit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
