Dumas 45" Scarab
I over the past year have taken a few pokes at it here and there. First was picking up the Proteus motor and I have an old Swordfish 240HV here to go with it
Next I did not like the stuffing tube alignment so I turfed that out as well as the Rx box and just did a general good cleanup As well as taking off that terrible winsheild that makes this hull look like a 20ft runabout:
As you can see I also ran across a STOCK cockpit for this baby. I did some extensive searches for these parts including writing to Dumas to no avail UNTIL... A fellow named Ken ( KenNJ) came onto the forum building this exact hull but with a custom cockpit area in mind( which he did masterfully BTW). So this is pretty much where this build will start, mounting that cockpit I think. It does seem to have its obstacles... such as it being warped a bit and just not cut out too square and there is every possibility that the hull opening was trimmed extra.
I have other bits as well such as my cable, rudders, and turn fins.
These big ones do seem to just sit in the background for awhile,hey Rick? I am looking forward to getting going on this. I have thoughts of a moulded plexiglass windscreen for her, something a bit more rounded on the top line. Any ideas are welcome guys.Comment
I did some rough mental math of the cost just before Christmas and had a shudder.
I'm also procrastinating reinforcing that massive bow. I figure one long bulkhead that sits in the keel and the groove in the top deck (can see that yours has that), but I'm a big guy with meat hooks for hands and sausages for fingers. I can't even touch the bow when I reach in from the hatch opening.
A plexiglass windscreen would look nice. What immediately popped into my mind was a style used on the Hydrostream's, but just keep the tapering off going towards the stern.
Mine has a windscreen built into the fiberglas of the top deck. Interesting design, but makes sealing the hatch a PITA...........another reason for the procrastination.Comment
I have the same hull, 1000kv on 6s to keep a scalish speed, great hulls and run very true............solid. My avatar is it..............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Yes it has Ken. Worked on doing some trimming this morning on that cockpit. Also tried heating the backside over some blocking material to straighten it out. Had some luck but I think some wood stringers will be necessary. There is lots of room within the hull so it'll be fine.
So that 1050kv on 8s shouldn't be too bad either. Though if I wire her up with a power block I do have 4 6s 3300mah cells. She should run for a bit on 13,000mah.Comment
I'm running 6s2p 10,000 mah and she goes quite a while, I'm fairly low amp draw though..............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Just my 2p adapters Rick. I just finished 4 of em for the R-42 as that is going 6s2p per side. Again 3300mah. I just run 1/8"copper thru connectors. Don't see why I couldn't do the same for 4p. I am contemplating getting the R-42 ones gold plated though, I would think it would help. And probably more so with 4p.Comment
I've made 2p adapters as well:
For a 4p set-up, I was thinking of a literal block that could be mounted on the hull between the battery banks. Same idea as a 2p adapter, but using potty epoxy (black) to encase everything. The battery side connectors would come out the top and the ESC side connector(s) out one end. There could even be a post for a spark arrestor.Comment
