fightercat daytona build
  • dude123
    • Jul 2014
    • 261
    Hey guys, a couple days ago i thought i should start a build thread about my cf fightercat Daytona and here i am haha. So i will update my progress with some photos tomorrow, but i thought i would go ahead and tell you guys what ive done so far and my plans. I haven't done to much lately mainly i have just put in the cf inlay which i will post pictures of. My plans for the power supply is going to be a neu 1521 1860kv on a pair of revoelectrix 6s lipos to start off with and maybe try 7s down the road. Esc wise i was thinking of running a swordfish 240 or a 200 Im not quite sure yet what esc i want to run so im open for suggestions. This will be my first build so take it easy on me haha, i guess well see how it goes!!!
    Every one knows the best part about building a boat is SANDING!!!! Just kidding
  • Make-a-Wake
    FE Rules!
    • 5557
    6s is already a bit much for that kv, I wouldnt even try 7s.
    • dude123
      • Jul 2014
      • 261
      Ok thanks for the input! 6s would be 41,292 rpms so so ya i think ill just stick their. Im not really going for sport running though.
        ive been running mine on 6s and 7s for quite a while now, no issues or signs of failure. I did run it on 8s once and the rotor wobbled, oscillated or something and contacted the stator and ripped the wrapping.....i think this was a result of a flip that happened so fast that i didnt let off the trigger and it free wheeled on 8s. Ive taken the motor apart numerous times for inspection and never had a problem until the 8s episode. so now i dont run it on 8s. would i run this setup in a heat race? definately not. Would I tool around the lake with it? I have and its been fine.
        • dude123
          • Jul 2014
          • 261
          Ya i think ill stick woth 6s for the most of the time and then if im feelin confident and alittoe more experienced ill bump it up a notch. So correct me if this wouldnt work but when im putting in the motor i was aning on tacking it in with some epoxy and then do the final seal with jb weld? Ive seen acouple guys doj g it and it looks reakly nice.
          • Make-a-Wake
            FE Rules!
            • 5557
            You can get all the speed you care to have within reason on 6s2p by prop choice, prop will have to be fairly small for 7-8s and all the extra strain on the parts at those rpms........just prop up, Neu's like to be loaded up and prefer diameter over pitch.
            • dude123
              • Jul 2014
              • 261
              Ya i was thinkingn at first just starting with a 442 and work my way up i wiuld liek to run a 645 possibly
              • dude123
                • Jul 2014
                • 261
                Ill get some pics coming when i get home
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  Here's a speed calc I did with an x448 at 85% efficiency and 25% slip which is conservative.
                  • dude123
                    • Jul 2014
                    • 261
                    Ok thanks!
                    • dude123
                      • Jul 2014
                      • 261
                      Were did you get the calculator ?
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        From the tab up top here on OSE. Your hull would have closer to a 20% slip.
                        • dude123
                          • Jul 2014
                          • 261
                          Ok thanks! What is the best angle for the drive shaft when i bend the brass tube?
                            when you prop up on these narrow hulls like that, you lots of handling issues. I prefer a smaller or medium size prop and a decent amount of rpm. i'm not scared of 40 to 45k rpm in what we are doing with the boat. Ive build a few for people like this and they work reliably.
                            • RandyatBBY
                              • Sep 2007
                              • 3915
                              That is a great 4S motor you can prop up to a X460 and still have long run time. You will be flying around 70tie with that setup.
                              Randy
                              BBY Racing
