CC Racing Storm Cat
  • oscarel
    • Dec 2009
    • 2127
    Originally posted by jhl1963
    Looks fantastic! Wondering if you can use a KBB seal setup with no tape.
    Thanks! I'll have to look into that. It's all finished. Hopefully weather will hold tomorrow and I can get a couple runs in. I had to use a different esc, got water damage on MGM from last race so it was sent back for repair. I've had a Jeti 300 pro sitting in the cabinet for awhile and don't have any other HV esc's right now. So here's where it's all at for now.
    • james himel
      • Dec 2014
      • 6
      great looking build. love that hull. I can't tell from the pics but what size rod are you using on that steering linkage and is it bent? From here it looks like it could be a little heavier duty.
      • oscarel
        • Dec 2009
        • 2127
        Thanks, the rod is 4/40 and yes it's bent. It's pulling so shouldn't be an issue.
        • oscarel
          • Dec 2009
          • 2127
          Weight was 8.2lbs empty and 18.4lbs RTR.
          • jhl1963
            • Apr 2014
            • 77
            You get a chance to run her? Curious! :)
            • oscarel
              • Dec 2009
              • 2127
              Not yet, been out of town and will be out of town again next week. Hopefully after that I'll get some time to play.
              • oscarel
                • Dec 2009
                • 2127
                Got a run in today, very happy with the results! Initially it looked to be running wet, but once it got going it loosened up quite a bit. Took a spill coming out of a turn but saw this on GPS and speed may not be totally accurate. Will get more running in hopefully next week.
                • oscarel
                  • Dec 2009
                  • 2127
                  Another run in today, speeds are holding in the low 70's. It was a little too calm today, with no wind the boat stayed glued to the water and it took a couple laps to get it freed up. Unfortunately on the 2nd run I hit something and tore up a good prop! So I'm going to try a 7014/2 375 PWW prop I have next week.
                    • 7673
                    She looks to be moving well Oscar. Sucks about the prop, do you know what you hit?
                    • oscarel
                      • Dec 2009
                      • 2127
                      Thanks! No, not sure what it was. My guess would be a log because it spun out when I hit and the strut has a chunk out of it too.
                        • 7673
                        Dang dead heads, I tagged something Sunday too. It was small(real small), but at 99.8mph the rudder got a little ding.
                        • oscarel
                          • Dec 2009
                          • 2127
                          #27
                          Ran the Storm in our first race this year and placed 2nd in open cat. I ran it with the PWW 7016/2 375 and didn't have a lot of prep time with it, boat was really loose and I flipped in the last heat, but managed 1,2,4 and dnf. The 4th finish I was in 1st place and cut a buoy. Next race is April 12th and I'll hopefully get a little more time to get things dialed in. Here's a graph from a test run before the race.
                            • 7673
                            #28
                            She is using most of that controller there hey Oscar, thanks for posting it. It is good info. All temps were good and all?
