Yep ! Ha ha ! I'm trying to do everything on this one ! Why not ??
--Albert Einstein
Sticky back LED flush mount turn signals . Half the weight and brighter too . For thermal switches.image.jpgimage.jpg
--Albert Einstein
I have 2 thermal switches so this time I will wire one switch to one light and one to the other. This way I will know what is getting hot .
--Albert Einstein
Next boat you'll need a small PLC or arduino board to control the ever expanding list of sensors and logic needed to control them. one thing i plan on putting on my fountain is a return to home feauture should my radio fail and lose signal. Its pretty common on planes so it wont require reinventing the wheel. Its a build of mine thats full of things that are there for my enjoyment and may ve considered unnecessararily complicated by some. It will be a continual build in progess using some of the new rc technology out there. Goal is to just get it water ready at the moment and then go from there. You'll like the wring arrangment in it, hope to update the build by the end of next week. Keep the ideas rolling and dont worry what anyone else thinks. I'm loving it!
--Albert Einstein
--Albert Einstein
--Albert Einstein
I added 2 more areas to plug into the thermal switches by using this electrical fitting. image.jpg
--Albert Einstein
--Albert Einstein
I didn't like the tiny barbs on the check valves so I put some JB weld on the barbs and pressed some aluminum tubing over them with my vise.image.jpgimage.jpg
--Albert Einstein
Ordered 2 , 8000mah 6s lipo's today . Good for 480 amps continuous and 640 amp bursts in 2p setup . I was thinking about running my m645 . 45,000 rpm setup so it should be fast. As long as 60+ is still fast
--Albert Einstein
Here is the final layout . I painted the back side of the center tray to clean up the look a little. Placed the check valves in easy to get to areas for servicing reasons( I left them wet for a couple months and the froze up a little . Compressed air fixed them right up). Just need to pull hardware to resurface the aluminum square bar clamp for the bolts , ad a hatch seal, get the reusable zip ties for the batts and finish re enforcing the stuffing tube on the bottom of hull. A few other things but basically done. image.jpg
--Albert Einstein
--Albert Einstein
I'm getting to the point now where I need to start thinking of a "look"... This is the only think that comes to mind.image.jpg
--Albert Einstein
