Aeromarine Team Believer with updated hatch build. Special
--Albert Einstein -
--Albert EinsteinComment
Now that's how you do it!
I may hit you up for some when I'm ready
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Any time Luck as long as there is heavy sacks of coin involved
Just need to insulate a few loose end and there ready
image.jpg"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
Looking great! You really dove right back into this build and tore it up!
What are you doing for battery trays? I noticed you had one 8000mah set on the tunnel, is that where you plan on leaving it? I ask because you'd be better served with them in the sponson, nice long ones you can use to set the cog wherever you please.Comment
Long Lexan trays ! They are drilled for zip ties and will have 2" Velcro . The center will have the same securement for 3p
I'm thinking of building a cap bank that plugs into the battery harness. Good idea ?"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
1st night of finishing the JB welding the battery trays in. I will get the other side tomorrow . $17.99 sheet of lexan goes a long way on this build ! The lexan actually is really stout once epoxied in.
