Damn those are some long battery wires, no wonder you have gone cap crazy.
Aeromarine Team Believer with updated hatch build. Special
Yeah no doubt . Bunch of 8 gauge there lol flows great though , never hit LV cut off and the 6s 2p discharged evenly . I just figured the cheesy caps of the v3 couldn't take the poke of a 59mm 1800 kv can lol"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
Is it absolutely necessary for the wires to be that long? In all honesty it's more important for your wires to be as short as possible than to worry about aesthetics. Not trying to undermine you one bit but I really think it's very important to make them a good bit shorter. Longer wores like that are causing a bit more unneeded stress to your power system. I'm unsure whether the caps will help as much as needed32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Is it absolutely necessary for the wires to be that long? In all honesty it's more important for your wires to be as short as possible than to worry about aesthetics. Not trying to undermine you one bit but I really think it's very important to make them a good bit shorter. Longer wores like that are causing a bit more unneeded stress to your power system. I'm unsure whether the caps will help as much as needed"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
Next thing I want to do is even up the drive dog with the rudder. This will bring it closer to an acceptable setup and should cut down on amp spikes a little bit when the nose goes high , along with the smaller prop I'm going to put on it .
image.jpg"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
