dismantel reconstruct
  • chrisholleyuk
    • Jul 2008
    • 10
    hi guys i need help with a boat, i want to strip my boat down an change the configeration off the layout. I have one motor but want 2 so i need to move the motor mount, propshaft an rudder? I have a battery/servo box in the way also. I think its two part epoxi resin holding it in but the hull is plastic an i dont want to crack the hull an help please thanks chris
  • kookie_guy
    • Jun 2008
    • 897
    if you are looking to remove the box without risking damage, get a dremel with a cut off wheel and go to town. Once you get it out of there, you can sand down the remains of the box with a sanding disc on the dremel
    • Steven Vaccaro
      • 8721
      Chris with the power of todays motors and batteries, you can use one motor and cut down of a bunch of work.
      • chrisholleyuk
        • Jul 2008
        • 10
        thanks iam looking to maybe go with two motors or one powerful in the middle off the hull to stop it porpusing, i dont no what to do though? or what to get
        • lonewolf
          • Jul 2007
          • 658
          For starters adding ore power will not fix porpiseing. I am not sure of what hull you re working on but every hull has it limits and issues, some are better han others. If you are looking for a fast well handleing boat I would suggest getting a fresh proven hull OSE has a nice line of hulls and nicely priced...
          Ok now on to your build.. first off that hull was vacuformed meaning the plastic was "heated" then formed. Ok the heat issue, Cutting and sanding with power tools will cause heat, this heat can warm the hull, nope ya cant fix that it will just get worse... But useing a dremel to carefully cut out the pcs do not try and force it there is a good chance of cracking...
          Useing a dremel for sanding is where you will run into the heat problem , most dremels run at a hi rpm to be effective , this hi rpm is what will cause the plasic to melt.....
          Ok so here we are again this is alot of work and will not fix the handling issue.
          You will just have a faster boat with bad handling. The odds are there is room for adjustment in the set up of the boat... Center of gravity is the best place to start, then there is trimming of the strut/singer.
          Plastic has a shelf life the older it gets and if exposed to sunlight for extending times it will get brittle. You may not find this out till you add the hi power motor and hit the throttle and the hull starts cracking.
          I am not trying to be a downer here but I am trying o save you alot of work that most likely you will not be happy with...
          If you are new to the f/e world I would highly suggest investing in a good fiber glass hull to start your build with. You will have far better results with alot less head aches. I almost quit F/E boating by trying to go at things the cheap way. Once you get your feet wet a bit then I would reapraoch rebuilding this hull.
          Best of luck Im on here most everyday and will offer my assistance.
          BTW I have been in he plastics industry for about 18 yrs Take my word for it go f/g....
          Oh be very carefull if you decide to try and use a dremel saw they can be wicked dangerous and when the jump the move faster than you
          Dave....
          Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
          • kookie_guy
            • Jun 2008
            • 897
            sweet jeebus!
            • blakybob
              • 126
              That's one knarley gash dude!!!
              Blake
              • lonewolf
                • Jul 2007
                • 658
                Yeppers no stiches tho.... I was useing a 1/5 hp dremel drive motor with flex the saw was a 60 tooth(I think) saw spinning bout 20 thou when it grabbed and jumped . I was holding the handle with that hand, happened so fast it did even bleed right away...... the blade was 1.25 in dia, it could have done worse.
                It happened Dec 23 07 and it is fully healed now but there is still a nice scar...
                When guys mention cut off tools and dremel I feel obligated to post a warning.
                Even the fiber cut off wheels will do the same damage. Or worse they can split and shatter going all over the room at mach 5 Wear safty glasses
                And most of all guys this is a hobby be SAFE it is not worth looseing a part of you that you were born with and would like to keep
                Dave
                • eclipse
                  • Oct 2007
                  • 365
                  is that another super hawaii???
                  • Chop
                    • Nov 2007
                    • 504
                    WOW!
                    Good advice Dave. Thanks for sharing your knowledge with us.
                    There is a fine line between "hobby" and "mental illness."
                    • chrisholleyuk
                      • Jul 2008
                      • 10
                      eclipse its not far off the super hawaii hull same boat jus a fed mods in factory before release
                      • eclipse
                        • Oct 2007
                        • 365
                        thats awsome you got anymore pics withe the haches on?here is a link of mine if you have time to check it out http://forums.offshoreelectrics.com/...ead.php?t=4001
                        • lonewolf
                          • Jul 2007
                          • 658
                          The silicone around the hatch, well its got to go if you ever plan on tapeing the hatch(recomended). I mean scape it till you get to the raw plastic, if you dont the tape will never stick. That will be the first of you problems, water and electrons do not mix and will cost ya $$$$
                          • chrisholleyuk
                            • Jul 2008
                            • 10
                            i put in the silicon, i work in the window fabriaction business an it works fine, an i can still tape it down no propblem
                            • lonewolf
                              • Jul 2007
                              • 658
                              I have never had any luck useing tape anywhere near silicone. I tape all my hatches even the ones with a gasket and latches....Dave
