Lauterbach GP Special.
  • olwarbirds
    Magic Smoke Wizard
    • Oct 2012
    • 1136
    #31
    Paul, Looking good ! .. I want some of that foam, looks like its easy to work with....DJ
    • 785boats
      Wet Track Racing
      • Nov 2008
      • 3169
      #32
      Yep. Good stuff DJ. It's two part closed cell urethane foam.
      I managed to get the top decks glued on over the weekend.
      Plenty of tape, clamps & weights did the trick.
        • 9488
        #33
        Originally posted by 785boats
        Mike.
        If it ends up reasonably light, I will run it on 8s with a 1530/1Y 1100kv motor.
        If it ends up a bit heavy I'll use 10s with the popular 1527/1.5Y 850kv motor.
        In either case the Swordfish 240A pro will be the ESC.
        In my U-95, which is the same length, I'm running the 1527/1Y 1250kv motor on 8s but the revs are a bit high, hence the 1100kv choice for this hull
        But if there are any other suggestions, I'm all ears.
        Cheers.
        Paul.
        Cannot wait to see the end results!
        a Friend of mine races one of these in the Gas class, and it runs Awesome!
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          #34
          I've had a bit of time to spare lately because the company I worked for went belly up a couple of weeks ago.
          So I've been able to do a bit on this one in the last few days.
          I've fitted the motor mount, strut, stuffing tube, water outlet & drilled the transom for the rudder.
          The strut mounting brackets were mounted on the inside of the transom & a slot cut through the floor for the strut.
          The motor mount that I had wasn't long enough so I added a ring & brackets behind it. Strengthened it up with a bit of a carbon fiber arrow courtesy of my son.
          I bought one of these dummy motor kits some time ago & have been cutting & sanding bits & pieces ready for painting & assembly.
          So the next thing to finish was the hatch.
          A bit of 1/16" ply for a top skin was glued to the frame.
          Looking at umpteen dozen pics of unlimited hydros showed me that the engine wold be sitting too high if I just glued it on top of the hatch. Even after I had cut the block down as low as possible. So I had to build a recess into the hatch like I've seen on other models. But then I had to cut a hole in that under the block where it hit the motor. Too easy.
          I've decided on the full size boat to model this one on. The "Miss America IV" U-36
          The graphics kit has been ordered from Mike at Thunderboat Graphics.
          Sorry, we couldn’t find that page
          It's good to be back working on this again.
          Cheers.
          Paul.
          • 785boats
            Wet Track Racing
            • Nov 2008
            • 3169
            #35
            A couple more pics.
            • tlandauer
              • 5666
              #36
              Words fail my admiration and appreciation of this kind of build!
              • olwarbirds
                Magic Smoke Wizard
                • Oct 2012
                • 1136
                #37
                Paul, looks great...sorry to hear about your work situation, you wanted a vacation to build boats anyways.... DJ
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  #38
                  Thanks guys.
                  The thing is, a job offer came up yesterday & although I wanted more time off, I had to take this one. Did the induction with the company yesterday afternoon & I start on Monday.
                  So that's the end of play time.
                  Oh! Well.
                  Paul.
                  • JimClark
                    • 5907
                    #39
                    Congrats on the new job
                    Sent from my SGH-T989 using Tapatalk
                    Billy Graham
                    • 785boats
                      Wet Track Racing
                      • Nov 2008
                      • 3169
                      #40
                      Thanks Jim.
                      • cybercrxt
                        • 2909
                        #41
                        Build looks great Paul. Sorry to hear about the job loss, but sounds like you are back in the game...Congrats! Mike
                        • 785boats
                          Wet Track Racing
                          • Nov 2008
                          • 3169
                          #42
                          Thanks Mike.
                          Yep. Working hard again. Lots of overtime for some good coin.
                          Not much time for building boats at the moment though.
                          • jwt
                            jwt
                            • Nov 2007
                            • 59
                            #43
                            Thanks Mike.
                            Paul
                            Working again is good,,, the HARD bit is hard to believe...
                            Tms
                            • olwarbirds
                              Magic Smoke Wizard
                              • Oct 2012
                              • 1136
                              #44
                              [QUOTE=jwt;573015]Paul
                              Working again is good,,, the HARD bit is hard to believe... Paul, glad to hear its all working out for ya... I finally got some of that 2 part foam, tks for the info. Your right its amazingly easy to work with...all the best... DJ
                              • 785boats
                                Wet Track Racing
                                • Nov 2008
                                • 3169
                                #45
                                What are you trying to say John???
                                I always work hard.
                                DJ.
                                Glad you like it.
                                Just a tip for you. If the weather is cold, heat up the tins of foam in some hot water first. In cold weather the foam expands less & will be more dense & heavier.
                                Cheers.
                                Paul.
