38,8" MHZ Racemaster build
  • Darkcyber
    • Nov 2013
    • 51
    #46
    next step
      • 7651
      #47
      Now would be a very good time to brush some liquid electrical tape on that ESC.
      • Darkcyber
        • Nov 2013
        • 51
        #48
        It will be a two-components heat-conducting dielectrical compound. It will be a good cooling system. Some photos will be after work
          • 7651
          #49
          That is a good idea.
          • Darkcyber
            • Nov 2013
            • 51
            #50
            Only photos. If you are has any questions, please ask they.
              • 7651
              #51
              Ok I have one, what kind of epoxy did you use there? The grey colour? That turned out very well by the way.
              • Darkcyber
                • Nov 2013
                • 51
                #52
                It is not epoxy, it's compound. I don't know, how it named at the USA. I was buy it at the radio-electrical components shop. http://www.chipdip.ru/product/kptd-1-1t-5.5-100g/
                As i write before, it's a two-components heat-conducting dielectrical compound.
                • Chrisg81983
                  • Jul 2011
                  • 1556
                  #53
                  Looks good....good luck with the maiden run hope it all works our for you. You did a great job with the controller.
                  • Darkcyber
                    • Nov 2013
                    • 51
                    #54
                    Hi to all! Bad news, ESC was breaked at the first drive on the water.
                    Further opening showed burned mosfets, four pieces
                    I will try t replace it and pressurize ESC seconnd time :)
                    Very like this ESC, nice working, nice construction and nice price and nice wires. Let me some lucky at this hard work
                    • Darkcyber
                      • Nov 2013
                      • 51
                      #55
                      Hi to all!
                      ESC repaired! Was replace 4 keys (1), 1 resistor 47 Om (2) and 1 chip (3). What is the reason of burning ESC i don't now. First drive will try next weekend.
                      • Chrisg81983
                        • Jul 2011
                        • 1556
                        #56
                        There is a reason why you keep killing controllers within the first few runs. If you are totally cooking etti 220's you will most likely keep burning stuff.
                        • Chrisg81983
                          • Jul 2011
                          • 1556
                          #57
                          If your video of the burnt etti is accurate, and the gallon of water I see in the boat was in there while u were running. I can pretty much guarantee that is what caused the etti to burn. It does not matter what the manufacturer says: about being waterproof. No electronic devices are waterproof at most they are water resistant / splash proof. Electronics and water just don't mix. There are also a few other things I see in the setup that could contribute to it but I would start with the water as being the culprit.
                          • Darkcyber
                            • Nov 2013
                            • 51
                            #58
                            You are mistake. Boat is always dry at the water, it is completely tight . You are see the water In my video with Etti because i was stew the boat after explosion. I was sink it to stop the open fire. It can't be the reason of the burning ESC. You are right, electronics and water can be mixing.
                            With the flier i think it was defects at the mosfets or control plate (chip)
                              • 7651
                              #59
                              Was that a newer release esc? Quality control used to suck for them but I know it has been improving
                              • robw
                                • May 2014
                                • 58
                                #60
                                I had a 450amp flier for a 1/5 truck, never worked from the day I got it, getting it repaired and converted to marine in the uk
