Hey I like the braid
my new carbon fiber cheetah!
32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I worked on it some tonight. Got the flex shaft cut and fitted. Had to mill the motor mount a tad so the bigger 4mm screws would fit. Then I made my cooling jacket. That didn't go so well. The carbon fiber tube I got was a tad too big on the inside diameter. So I machined some thin spacer rings to be epoxied on the inside. That came out pretty nice but after sliding the sleeve on, I could not rotate it to line up the hose nipples. Hmmm. Just would not move nor come back off. I have to cut it off. Once I got it cut off I noticed that I nicked the fins all the way down the motor. Nicebrand new motor with grind marks on it. I took it apart and chucked the can up in my lathe and skimmed the fins a few times times till the marks were gone. I figured while I was at it, I'd open up the gap on the end fins a tad so I could fit a thicker oring and now I don't have to make spacers. That worked out much better.
Heres the motor mount after milling itAttached Files32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Did you use oil to put the jacket on?Comment
20131123_233629.jpgGot the water jacket finished. This pic is before the nipples installed. Gotta figure out a rear support now.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Yes I made that and machined the motor can a little to make it all go together better. The posts are for the steering servo plate. Not really a fan of it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Why don't you care for the servo plate? I build almost all my cats with them. I think they look a lot bettet than any other mount. Plus you get the additional carbon bling.Comment
Nice work, I didnt know you had the lathe and mill available. If you dont like it, make it disappear and put something in that you do like. MHZ makes a nice looking servo mount, might be good for ideas. good call on the custom water jacket, thats the stuff I like!Comment
I made the jacket out of carbon fiber so the diameter would be smaller. Easier to fit in the motor mount. Im thinking about ripping it all out and making my own mounts now. The mount that's in there is really too short for the motor and im having a hard time thinking up a rear support.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
You could machine an aluminum ring up and add seperate mounting tabs for it. OR, I am all for ripping it all out and you doing a complete custom job on it. Make it a little more bulletproof to handle that big motor. You know its going to see some high speed unexpected flight sessions while you test the limits. So many options...Comment
