The "Bling Rocket" build
    • 7673
    #76
    It's gonna be a bit tight but that tab may be leaving
    • lenny
      • Sep 2010
      • 4294
      #77
      The black just makes it look so much cleaner than mine does,
      Ok god dammit gump where is that can of glossy black paint ?
      If I had mine setup like yours that tab would have to go,
      It will look a lot better with out it anyway.
      It is weird some have the tab and some do not.
      My old one has it and the new one I just got does not,
      Not really sure what it's purpose was for.
      Because it is not very strong as it is to be a hatch hold down mount.
      ? ONLY IF THEY WORK
        • 7673
        #78
        I had thoughts of using that one Aeromarine hatch lock that I now have here. But just one, probably not enough. I will examine the subject tonight.
        I am getting excited about paint and have a plan goin' in my head. I have to keep up with Lenny's fantastic looking one.
        It has been awhile since the paint has excited me, which is good because I have the Komodo to paint and put to rest too.
        • lenny
          • Sep 2010
          • 4294
          #79
          Just one is what I was thinking of using to,
          But not there on that tab.
          Because since I got this boat and have been running and testing it,
          It flipped once on me going over a jet ski wake and rolled landing on the hatch that I only had may be three 2" pieces of tape on.
          And the hatch stayed on with very little water that got in the hull,
          Because I hate using the tape when testing and taking temps & gps reading all the time,
          So I like to use one or so thumb nuts and some kind of seal on the hatch or on the hull opening.
          I did my Bolt hydro something like that and it works great with no tape,
          And that is what I was going to do with this boat to as well the rest of my boat in time.
          Hear what I did to the hydro Bolt and was planing to do for the Pursuit to,
          It pulls all four corner down at one time on this for a good seal.
          That I held the boat under water and nothing got in,
          But it need to look good to.
          Pictures of 36 shockwave 047.jpgPictures of 36 shockwave 041.jpgPictures of 36 shockwave 042.jpgPictures of 36 shockwave 044.jpgPictures of 36 shockwave 045.jpg
          ? ONLY IF THEY WORK
            • 7673
            #80
            There are some good door/window soft seal that I have used for a few of mine Len.
            So my first glitch occurred when I went adjust the back of the up. The cap screw and come washer were too long and hit the tailring.
            So I dug around and found a taper head screw and matching washer. Lucky
            • gsbuickman
              • Jul 2011
              • 1292
              #81
              Originally posted by srislash
              Alright, the planned mission has been completed. I got the mounts, stringers, trays all in (and the other necessary household chores).
              [ATTACH=CONFIG]107456[/ATTACH][ATTACH=CONFIG]107455[/ATTACH]
              Just got to roll a bit of epoxy down the top of stringers under the deck this morn before work.
              Hell yeah Slash, she's lookin' good bro. I like it :-)
              • Fella1340
                • May 2013
                • 1035
                #82
                Looking fantastic! I really like the combined motor mount /.servo mount. That's just good thinking!
                  Looks great! Got a question...how do yiu secure the batteries with the slots running that direction in your battery trays? Mine go the length wise.
                  Like this
                    • 7673
                    #84
                    Thanks for the appreciation guys. I like how it is coming together.
                    Like this
                    [ATTACH=CONFIG]107508[/ATTACH]
                    [ATTACH=CONFIG]107509[/ATTACH]
                    I have they trays spaced up a bit with the tabs that come with them. Then I can Velcro right around tray and battery,can do length wise as well if need be.
                    Started on the final stuffing tube this AM so I can get the flood tube in. Still haven't quite figured how to seal the front of the tube by motor. So far thinking some soft closed cell foam. Have to check what is at the Foam Shop.
                    • rickwess
                      • Apr 2013
                      • 777
                      #85
                      Keep up the good work. I'm getting lots of ideas.
                      I just ordered my hull yesterday.......a Insane 34 mono with CF sandwiched between the layers of S-Glass they normally use. Now the waiting game begins.
                      • Fella1340
                        • May 2013
                        • 1035
                        #86
                        I ordered a sample pack with my last cloth order and of had a sample of.the S-glass in it. I was
                        quite impressed with it. If I end up with a glass job to do that's what I think I will use. Side by side
                        with. fiberglass isn't even a fair comparison. Sounds like that will be one tough hull!
                          If you don't mind, post a pic up with a battery mounted so I can get a visual of what your talking about when you get a chance. Thx
                            • 7673
                            #88
                            I'll post it tonight bud.
                            Kinda surprised I have had no comments on my cockeyed motor mounting.
                            • lenny
                              • Sep 2010
                              • 4294
                              #89
                              Ok,
                              I think if your blind you did a very good job on the motor mounting.
                              ? ONLY IF THEY WORK
                                • 7673
                                #90
                                Originally posted by lenny
                                Ok,
                                I think if your blind you do a very good job on the motor mounting.
                                Well... I'm not blind,hehe. I used to do this in the old brushed days to help with torque roll. Really helps on a rigger on takeoff.
                                Thanks for biting Lenny.
