The "Bling Rocket" build
  • rickwess
    • Apr 2013
    • 777
    #31
    Looking good Shawn. I'll be following this close since I'll building a DF Pirate 35 over the winter..........LP 4082 1600kv, 6s2p. It'll be my 2nd boat, but my first build.
    My biggest concern is being able to keep the CoG correct in both directions. As you have pointed out already the main influencer will be those big a$$ 6s's. I was thinking of a similar layout as yours, but I've noticed most here like to move the motor much farther toward the bow. Your layout is very similar to that of the Revolts (my first boat). The CoG was really easy to adjust once I pullled the stock tray out and replaced with CF. Like on the Revolt, have you thought about placing the ESC beside the motor on the opposite side of the Servo? It would eliminate the PITA factor of having to move the ESC to pull the batteries.
    I like your CF work. What tools do you use to make them?
    I was going to reinforce the bow of the boat using the very unimaginative method of 2 part foam. I do multiple smaller pours so to make sure I get an nice even fill, grind the front face flat and square then glass it in.
    • rickwess
      • Apr 2013
      • 777
      #32
      Sorry, I have a really basic question that I want to ask. What's the purpose of a flooded tube? I'm thinking that unless the boat is stationary, that tube tube isn't flooded.
        • 7673
        #33
        Haha , yeah not flooded but leaves room for strut adjustment. A tedious setup with such a short stuffing tube keeping alignment and adjustability. I have been moving the stinger around on my 35" DF trying to get it "settled". A lot of disassembly and resin work for that.
        BTW went with bulkhead instead of foam as I cannot be certain of the weight of the foam till I do one. Thought about it though. I know others here have done it and added 2lbs of weight to the cats.
        • martin
          • 2887
          #34
          Flooded tube is just a term used because the tube is a large diameter tube open at the transom, the idea of the large diam tube is to give a lot of up or down adjustment of the strut as the stuffing tube is only attached at the front of the flood tube. Hence allowing a bit of bend in the stuffing tube when moving the strut up or down.
          • RandyatBBY
            • Sep 2007
            • 3915
            #35
            The stuffing tube will take the path of least resistance. It will move the sealer on the end of the tube and not bend the stuffing tube.
            Randy
            BBY Racing
            • rickwess
              • Apr 2013
              • 777
              #36
              That's a lot of foam. When I foamed the bow of my Revolt, I used about 1 dixie cup worth of liquid.
              What are you using to form the CF parts?
              • rickwess
                • Apr 2013
                • 777
                #37
                Ah, makes sense. I was taking the term too literal. Obviously not possible with a stinger set-up.
                • martin
                  • 2887
                  #38
                  Yes I should of used the term allowing the stuffing tube to flex with movement of the strut rather than the term bending the stuffing tube.
                  • gsbuickman
                    • Jul 2011
                    • 1292
                    #39
                    Good information for the day, but 2lbs of foam weight does seem like a lot. Are you referring to a type of spray in expanding foam, or the mix Ina cup pourable foam ?.
                    The entire nose of my mm cat is sprayed in. It seems like a lot of foam was used in this thing, but I doubt it'll weigh a pound
                      • 7673
                      #40
                      I had merely read the 2lbs in a thread but it seemed to stick in the brain. I will try to keep track of the weight added by various things here (ie:bulkheads,inlay, and such). Just be good knowledge.
                      • RandyatBBY
                        • Sep 2007
                        • 3915
                        #41
                        The 2Lbs was for a cubic foot. If you can find it, there is one pound per cubic foot foam. that should make it easier for you.
                        Randy
                        BBY Racing
                          • 7673
                          #42
                          Good to know Randy, thanks.
                            I like this little boat. Where can I get one? Fightercat is out of stock.
                            • lenny
                              • Sep 2010
                              • 4294
                              #44
                              I think HK has them in stock.
                              http://www.hobbyking.com/hobbyking/s...Hull_Only.html
                              ? ONLY IF THEY WORK
                              • tiqueman
                                • Jul 2009
                                • 5669
                                #45
                                looking good Shawn. I rebuilt my pursuit before I sold it moving the motor back and what a difference. Your on the right track
