I'm with Jim on this too. I plan to have the prop about 1/2" from the transom.
BBY Micro Turbine Hydro for SSSH
I have massaged the drawings to a point where I have all the parts and I think everything will fit. I need to add retention gaps and populate a sheet equal in size to the piece of plywood I’ll be cutting, but that is only a few minutes work. I’ll make as many parts as will fit on a sheet. Hopefully, by this time tomorrow the laser-cutter guy should have the drawing files and will be reviewing them.A nation of sheep breeds a government of wolvesComment
Will this do the trick? The mounting foot measures 5/16" x 1/2" and the rudder blade measures 1/32" x 3/4" x 2 1/2". The rudder will be 13/16" from the transom. I need to locate a proper fitting bellows type control rod seal yet but other than that I may make a few in the next week or so. I ordered a motor and esc from that place in China. Once that comes in I can start picking at a micro too.
So what do you figure these rudders would cost? I may just have to make another try on a 1/24th scale Hydro
Jim
Billy GrahamComment
Joe,
Here is a thought I had: It looks like your design will allow the linkage to be on either side of the rudder by "flipping" the bracket and linkage arm (ball link shown). I prefer the servo linkage rod to be in tension for a right turn rather than compression. A long rod can flex when in compression. Will your proposed design allow for this?
Another thought or two: Could you put a radius on the upper leading edge of the rudder blade allowing it to "kick up" if it hits an obstacle? For the bellows, I have found an internal bellows works well when room is limited.Attached FilesA nation of sheep breeds a government of wolvesComment
I have enough laser-cut parts for three prototype hulls coming in the mail, and they should arrive today or tomorrow. They may be on my doorstep when I get home from work today. I will quickly throw one set together and test-fit it into the hull. If I need to do any revisions to the CAD drawings, this will be the time.
The plan is to assemble the framework with thin CA, then paint the entire assembly with thinned epoxy to waterproof and secure all joints. After the water-proofing is done, the framework will be installed in the hull using expanding polyurethane glue. This stuff sticks anything together, fills gaps, floats, and probably improves your karma as well.
I will first glue the framework to the bottom hull half. After that has cured, I will install foam floatation in the sponsons with the PU glue. After that has cured, I will shape the foam to fit the deck, then I will apply a bead of PU glue to the top of the hull where it contacts the floatation, the framework, and where the two halves join. Then, while the glue is still liquid, I’ll tape the halves together, check for a square hull, then, leave the hull upside-down for the glue to expand and cure.
Once everything has cooked off, it will be time to cut the hatch open, mark the hull bottom for the stuffing tube, install the motor mount, stuffing tube and stuffing tube spine. As before, the wood assemblies will be assembled with CA, painted with epoxy, and installed in the hull with PU glue.
Hopefully, I will have a super-stiff, yet light hull at that point.A nation of sheep breeds a government of wolvesComment
Joe,
For the bellows, I have found an internal bellows works well when room is limited.Comment
Billy GrahamComment
God, I love the smell of burnt wood!
I need to make the transom a bit narrower, and move the front cross-piece back a few thousandths, but overall, it fits. The changes can be made on the prototype framework with a file and some sandpaper, so all is well for the build from here on out.Attached FilesA nation of sheep breeds a government of wolvesComment
I jsut bought one of these Hydro's the other day.
Cant wait to start in on it.
Curious to see how that motor will work. Seems a bit small compared to Randy's suggestion?42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
