BBY Micro Turbine Hydro for SSSH
  • Dr. Jet
    • Sep 2007
    • 1707
    #31
    Sketches
    Here is a preliminary sketch of the forward bulkhead based on the published dimensions of the MHZ propshaft. I'm thinking of running a "spine" down the centerline of the stuffing tube to keep it from flexing.
    A nation of sheep breeds a government of wolves
    • Dr. Jet
      • Sep 2007
      • 1707
      #32
      I have been doing some research on the seller’s store for the “Spec” motor supplier. He has some 9-gram servos in a six-pack for about $5 each. I may add a servo mount in that spine I am planning and size it for these servos. That way, if you get the motor from them, you can order a servo and possibly save on shipping costs.
      I have more ideas on this topic that I will reveal when the time is right.
      • RandyatBBY
        • Sep 2007
        • 3915
        #33
        Originally posted by smm_cbf
        what you just said makes me feel alot better, i got my boat up for sale now, i have to sell my other boat in order to build one of two of these boats. i kind of like the mhz shovel nose, and the geko.
        That is one thing I hate to do sell one project to fund another. That is a last resort to me. The BBY hull is real cheap.
        Randy
        BBY Racing
        • RandyatBBY
          • Sep 2007
          • 3915
          #34
          Originally posted by J Solinger
          What is the transom width and height on the bby hydro? I will do some chewing on it.
          The way I build mine I measured 7/8 of a inch for the transom and my bracket is 3/4 of a inch. It would be nice to have a machined bracket, I will be watching to see what you do.
          Randy
          BBY Racing
          • Dr. Jet
            • Sep 2007
            • 1707
            #35
            Randy,
            My preliminary plans are to have the front edge of the prop hub (where a drive dog would normally be) ½” behind the transom and ½” below the bottom of the hull (even with the sponson bottoms). As you can see from the sketch, I will have about 6-1/4º of “down” angle at the prop. The Graupner props are very similar to an Octura “X” series with some tongue removed, so I gather they are low-lifting like the Octuras
            • Darin Jordan
              • 8335
              #36
              Seems like a perfect application for a .047" Wire Drive...
              Darin E. Jordan - Renton, WA
              • Dr. Jet
                • Sep 2007
                • 1707
                #37
                Wire Drives
                I have successfully used 0.030" wire drives in my other SSSH models. I wanted to do this one with a straight shaft to keep it simple and cheap.
                • Dr. Jet
                  • Sep 2007
                  • 1707
                  #38
                  MHZ Rudder
                  Here is an interesting tidbit. I just received an email from MHZ telling me the rudder assembly I have is no longer available. I sent a response with the part number I have, just to confirm. I’ll let everybody know what the response is.
                  Joe,
                  If you are reading this, then the need for a decent micro rudder has moved up the priority scale, and you may be just the person to “do it up right.”
                  • Dr. Jet
                    • Sep 2007
                    • 1707
                    #39
                    Fast Response from MHZ
                    I just received a response from MHZ to the email I sent out a couple of hours ago. This email said the rudders are temporarily out of stock and should be back in stock very soon.
                    Still, I think Joe could come up with something way cool.
                    • J Solinger
                      • Apr 2008
                      • 197
                      #40
                      I am curious to see how the straight drive shaft works out. I have been designing around a wire drive but a straight shaft would simplify things a bunch, and reduce costs.
                      Joe Solinger
                      • JimClark
                        • 5907
                        #41
                        With the motor so far forward isn't it going to mean the battery is going to be midships and the CG will not be in a good position?
                        Jim
                        Billy Graham
                        • JimClark
                          • 5907
                          #42
                          Being the scale geek that I am having the prop so far back of the transom just looks very wired to me. Does it really need to be back so far?
                          Jim
                          Billy Graham
                          • Dr. Jet
                            • Sep 2007
                            • 1707
                            #43
                            Bullseye Joe, that's the whole idea!
                            • Dr. Jet
                              • Sep 2007
                              • 1707
                              #44
                              Progress
                              I've been working on the drawings, all that remains is the transom and the cross-pieces at the front.
                              I printed the drawings and ironed them onto some balsa for a test-fit. Here's what I have thus far.
                              • G Doggett
                                • 446
                                #45
                                Jim
                                I'm with Jim, I don't mean to be critical but why on earth is the prop so far behind the transom ?
                                This 'stinger' type strut is only used on DV hulls to get the prop in clear water, hydros work fine with the prop close to the transom.
                                Graham.
