Would if I go with the leopard 4082s instead? This video is so tempting... http://www.youtube.com/watch?v=sK_VYTokzLQ
37" Genesis Build
Would if I go with the leopard 4082s instead? This video is so tempting... http://www.youtube.com/watch?v=sK_VYTokzLQMy private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Comment
Ok. I figured the coupler or whatever was just loose. So you guys are saying my setup will be pretty fast? I've built rc brushless boats before just never fully understood the electronics part.After all is said and done, more is said than done.Comment
I would assume that you will run a 4s battery PER MOTOR/ESC (or as mentioned above you could run a 4s 2p in one single battery pack) per motor. Beware though, you may not fit the 4s 2p packs in the hull - someone with a genesis twin will need to varify this as I have a genesis single and they wouldnt fit in the sponsons from my reckoning, however you may fit them as they will be positioned in the centre of the hull for your application.Comment
4s 2p is only if you buy a 4s 2p battery. If you buy a 4s battery, you will not be running them in (2p) parallel as if you were running a single motor. To do so you would be running 4 battery packs which is way too heavy.
I would assume that you will run a 4s battery PER MOTOR/ESCAfter all is said and done, more is said than done.Comment
